Weber hot water
trialsrider Avatar
trialsrider Silver Member Richard Bussler
South Williamsport, Pennsylvania, USA   USA
A question about the hot water line that goes through the intake manifold . should you use ,does it help anything other than faster warm up?
tvrgeek Silver Member Scott S
ABSOLUTELY. I had a heck of a time getting warm up and cool weather smooth until I added it. It also helps greatly to prevent the manifold from getting too hot and boiling your bowl. This is why almost all manifolds have this capability, including the TR-6 from the factory. It helps against cold wall dropout.
Now, many here will disagree. They are "experts". I can only tell you I chased my tail for weeks until I put on the water and ignored the experts. All those who claim it reduced HP have not done the math or think intuition is smarter than physics.
trialsrider Avatar
Not really concerned about h p just. A driveable car with no stumbling or hesatation
Add the water and follow Michael's setup guidelines. Put in a decent ignition and it can run like a production car. I would include an appropriate advance curve and vacuum control in the "decent ignition".
trialsrider Avatar
The b has a Mallory duell point dissy no vacuum adv .
TD10971 Avatar
TD10971 Nelson K
long island, NY, USA   USA
check the condenser......my old duel points dist would foul out the condenser once a year
In reply to # 3641300 by trialsrider Not really concerned about h p just. A driveable car with no stumbling or hesatation
Aridgerunner Avatar
Montoursville, PA, USA   USA
1956 MG MGA 1500 "The A"
Stop fighting!
According to the dictionary the word duel is: a prearranged combat between two persons, fought with deadly weapons according to an accepted code of procedure, especially to settle a private quarrel.
You guys meant dual didn't ya?
That's my brother, getting in hot water again.hot smiley
Bealey Avatar
Bealey Silver Member Joe & Barb Hahn
East Wenatchee, WA, USA   USA
1971 MG MGB "Bealey"
1974 MG MGB GT
I didn't like the looks of all the plumbing required to have hot water to the manifold all the time so I plumbed the heater return line through the intake and it seems to work just fine plus I don't have a separate heater return line to deal with. We do live in a desert area, Central Washington State, so definitely not a problem in the summer months as the temps usually exceed my tolerance for heat. smiling smiley
On a semi related subject, a lot of folks don't realize that back in the day of all cars having carbs that the idea behind the stock thermostatically controlled air cleaners was that they would suck some hot air from the "stove" located on an exhaust manifold so the air entering the carb would be at a balmy 135 degrees F to improve atomization of the fuel and help prevent cold wall drop out.
Joe
Edited 1 time(s). Last edit at 2017-12-07 11:20 AM by Bealey.
IMG_7550 (Medium).JPG    53.4 KB
trialsrider Avatar
With the water pipe hook up. Run up to temp ,adj mixture screws it runs much better unfortunately I can't drive it right now as it is stripped for paint .it'll have to wait till spring.
Get rid of the dual point
trialsrider Avatar
Sorry rob the dual point stays ,besides whats wrong with that
It's useless on a. B
IT has no vac advance
IT does nothing for performance on a street engine B
trialsrider Avatar
Did you read all the posts rob ,not interested in more performance .this dual point has been in this car for at least I5 years and it works fine so it stays.
Edited 1 time(s). Last edit at 2017-12-07 03:25 PM by trialsrider.
I read you wanted drivability.
Good luck
trialsrider Avatar
Well rob the car ran just till the accelerator pump in the pos Weber went south
