Jacking Up Car AFTER Removal of a Motor Mount?
JGORMAN Avatar
JGORMAN Joe Gorman
Petersburg, TN, USA   USA
Replacing the front motor mounts on my '80 MGB. I've raised the motor with a trolley jack and a piece of 2x6 under the oil pan, and removed the passenger-side mount, but have not yet replaced it. I discovered, however, that the driver-side will be easier if I have more room under the car. So..., I need to raise the front of the car. If I lower the motor, WITHOUT replacing the passenger-side mount first, will I damage anything? I want to 1) lower the motor, 2) raise the front end and place on jack stands, 3) raise the motor again.
Difficult enough of a job on a packed gravel barn floor, with no heat.
Thanks,
Joe Gorman
Petersburg, TN
RAY 67 TOURER Avatar
RAY 67 TOURER Ray Marloff
Fort Bragg, CA, USA   USA
1967 MG MGB "My Girl"
Joe, place a small piece of wood where the missing motor mount was and then lower the engine down on it. RAY
barry s Avatar
Alexandria, VA, USA   USA
1972 MG MGB GT
1976 Triumph TR6
Why not just replace the missing mount and then move to the otherside? Am I missing something?
JGORMAN Avatar
JGORMAN Joe Gorman
Barry,
The replacement mounts haven't arrived yet. Just getting ready for the new ones.
late 64 Terry O
Milton, Ont, Canada   CAN
X2 Ray.........thumbs up
tbarker7815 Avatar
tbarker7815 Tom .
Knoxville, TN, USA   USA
To access the nut on the drivers side mount is pretty tight, I took a cheap open end wrench and ground it down thin to fit in.
spikemichael Avatar
Ocean Shores, WA, USA   USA
1973 MG MGB "Freebie"
1974 MG MGB "Spike"
X3 Ray
The driver's side mount is often a bear for people. I did it on the '79 in no time flat was surprised how smooth the process was. Did it on a '76 without much issue either.
Never had to do a passenger side (knock on wood)
Michael J. Caputo
Donthuis Avatar
Donthuis Don van Riet
Before replacing my sump gasket I decoupled both mounts and lifted the engine up symmetrically. With two woodenblocks instead of the mounts, the block stayed up enough for reaching those bolts.
Although your job and mount type are different, I feel lifting the engine up slightly and using wooden blocks in some part of the process is quite easy eye rolling smiley
