Residual brake pressure valve question.
When I was buying all my bits for the GT's two master cylinder set up Wilwood suggested I get a Residual Pressure Valve for the rear circuit so I did. Their instructions (in the hot link) suggest putting the valve as close as possible to the m/c. I can do this but I was wondering what happens if I place it where the stock system has the joiner #6?
Edit: I did not Underline the Bold Italics but it happened automatically. Some folks don't like Underlined Bold so I was trying to be more compliant; IDK how to fix. smiling smiley
Edited 2 time(s). Last edit at 2017-12-06 01:32 AM by MGB567.
joiner.jpg    26.6 KB
spikemichael Avatar
Ocean Shores, WA, USA   USA
1973 MG MGB "Freebie"
1974 MG MGB "Spike"
Barrie, your master cylinder is not below the caliper or wheel cylinder, why would you need this?
Michael J. Caputo
I only had Wilwood's advice to go on:
"Since you’re using rear drums we strongly recommend adding a 10 lb residual pressure valve within 12” of the master cylinder on the rear brake line. This will help prevent your shoes/springs from closing the wheel cylinder at rest."
spikemichael Avatar
1974 MG MGB "Spike"
In reply to a post by Wildwood A residual pressure valve is used when a master cylinder is mounted equal to or below the
horizontal plane of the calipers or drum brake wheel cylinders. This valve prevents fluid flow-back
to the master cylinder reservoir which can cause excessive brake travel or “pumping” of the pedal
to engage brakes.
Michael J. Caputo
Edited 1 time(s). Last edit at 2017-12-06 02:15 AM by spikemichael.
Mmm. Perhaps I should have read their blurb (and before posting) rather than relying on their advice (seems in retrospect just a ploy for me to have spent more $). Oh well another $20 to help US balance of payments and another thing for the trinket box. Thanks for reading for me.
melbaver Avatar
1968 MG MGB "Moneypit"
I think we need a competition, here in Australia, to design and manufacture an object out of excess MGB parts. Will not be very costly for the parts, but the combined freight cost would be astronomical.
Chris Howells
tvrgeek Silver Member Scott S
Most twin circuit MG master cylinders have such valves built in, which causes it to be a pain to gravity bleed them. "Trap Valve" as they are called. Without such a device, first time you press the brakes, it is a longer travel. Rest of the trip is fine.
Try it without and see how it works. If you have a long petal, put it in. I am not sure where in the circuit makes that much difference.
Wachtmans Avatar
Wachtmans Wouter Strodijk
1974 MG MGB "The Bee"
1974 MG MGB MkIII "The Bee"
I tried that once (without trap valve). Pedal gets real long without. The springs in the brake drums tend to retract the brake cylinders far in, especially when new, which makes the pedal long.
geezer Avatar
Magee, MS, USA   USA
1974 MG MGB GT
I can attest that the residual pressure valve is needed when the M/C is below the floor of the car. When I did my disc brake conversion on the Morris Minor I had a very long pedal before installing the valve.
I just completed a rear disc conversion on the '74 GT and am contemplating on removing the trap valves from the M/C. I do have a good pedal feel as is. The problem is I'm not getting pressure/flow to the rear brakes. What is the purpose of the "trap valves" and are they the same value for the front and rear circuit in the stock dual M/C?
Wachtmans Avatar
No, this trap valve is standard for the rear on a dual brake system. Has nothing to do with bleeding. Start with bleeding the right rear, then left rear then right front and last left front.
spikemichael Avatar
1974 MG MGB "Spike"
oh boy another brake bleeding thread haven't seen one of those in a while!
Michael J. Caputo
I believe this was directed my way. I think you miss-read my comment. It makes GRAVITY bleeding more difficult. Other methods are no different.
As you can see from the Moss diagram, the valves are in both circuits.
https://mossmotors.com/mgb/brakes/brake-master-cylinder-hydraulics/dual-line-non-servo-brake-master-cylinder-1968-74-5 ( item # 21)
In reply to # 3640883 by Wachtmans No, this trap valve is standard for the rear on a dual brake system. Has nothing to do with bleeding. Start with bleeding the right rear, then left rear then right front and last left front.
Paul755 Paul H
Richmond, VA, USA   USA
1974 MG MGB MkIII
1979 MG MGB MkIV "Nemesis"
The residual pressure valve also keeps some pressure on the rear wheel cylinder piston seals and is supposed to also prevent the cylinders weeping brake fluid. Or at least that is what my MG TF workshop manual claims.
The rear brake adjuster prevents the rear shoe springs retracting the rear wheel cylinder piston beyond the set running clearance.
Denis Avatar
Denis Denis Hill
Barrie it is normal on production cars that have disc / drum setup to have a residual pressure valve in the "drum circuit" built into the master cylinder. Cant do any harm and will improve the pedal feel.
Denis.
So I should take Wilwood's advice and insert it around 12" or less from their M/C?
It makes a difference because I'll be getting HEL to fabricate lines so at present I'm determining brake line length and position (using 7mm OD clear plastic tube).
