How much does the front suspension assembly weigh?
PARISH-63MGB Thomas Parish
Westford, MA, USA   USA
1963 MG MGB
I am planning to remove the front suspension from my 63 MGB and rebuild it over the winter. I would like to do it in my basement where there is actual heat - as opposed to the garage which is freezing. My question is how heavy is the assembly? My basement access is through a bulkhead with 5 steps. With two people, will I be able to reasonably get it down those steps to get it into the basement? Thanks.
CMCon98 Colin C
Dedham, MA, USA   USA
I've been wondering about this too. It seems like in a worst-case, you could strap the assembly to a two-wheeled handcart like they use to move refrigerators and take it down a plywood ramp into your basement.
converse212 Avatar
converse212 Eric Morgan
Tucker, GA, USA   USA
1958 MG MGA
1970 MG MGB "Daily Driver"
1970 MG MGB GT "Rusty"
1971 MG MGB GT    & more
In reply to # 3627532 by PARISH-63MGB I am planning to remove the front suspension from my 63 MGB and rebuild it over the winter. I would like to do it in my basement where there is actual heat - as opposed to the garage which is freezing. My question is how heavy is the assembly? My basement access is through a bulkhead with 5 steps. With two people, will I be able to reasonably get it down those steps to get it into the basement? Thanks.
Two reasonably fit/sized people can move the front suspension. I’ve moved them by myself before, not for the faint of heart...suggest a moving buddy.
Alternatively, if you remove the four bolts holding the shocks on and the four bolts moving the inner pivot for the lower control arms, the weight is split almost into thirds and very easy for one person to move in three trips
Daily driving a '71 MGB
Resurrecting a '58 MGA
okephoto Avatar
okephoto Kevin Oke
Duncan, BC, Canada   CAN
I'm not sure of the weight but I moved mine by myself. I would guess 75 lbs.
Mgb1967.com A restoration & historical journal
Mgb1967.com/mg-resource-directory/ MG Resource Directory
In the family for 50 years, and presently in what is becoming an expensive overhaul!
Perdido Avatar
Tuscaloosa, AL, USA   USA
I removed mine by myself and used a jack to get it out from under the car, but put it on saw horses by myself...should be easy for two people to carry.
Rut
1970 MGB, Pale Primrose
1967 Triumph TR4a
1966 Triumph TR4a
1963 MG MGB
Thanks to all -- I think I will go the route of breaking it down at least a bit before moving to the basement. Appreciate the help.
okephoto Avatar
okephoto Kevin Oke
Have fun, it's well worth the effort. My suspension is in my office this winter!
Filthy MGB GT suspension.JPG    56.8 KB
Painted MGB front suspension parts.JPG    47.9 KB
mowog1 Avatar
Saint Joseph, IL, USA   USA
1969 MG MGC "Vicky"
1972 MG MGB "Mallard"
The crossmember that I removed from my 1974-1/2 MGB/GT...with all ancillaries attached....weighed in at #180.
mowog1@aol.com
Stock crossmember_1.jpg    63.5 KB
Stock crossmemember_2.jpg    70.9 KB
Bill Hibberd Avatar
Looking pretty sweet there Kevin. Good to see that you are getting good use out of your new blaster. Are those new coils? If so, which ones did you go for?
COMING SOON. COMING SOON. COMING SOON. COMING SOON. COMING SOON. COMING SOON. The first in a series of limited edition fine art paintings featuring our favorite LBC, the MG. Combining my love of painting with my growing interest in all things MG.
fast-MG.com Avatar
Remove steering rack first. Then the suspension corners. Then the X-member. Assemble to the car in reverse order. Bare X-member is easier to bolt up to the car without all the other stuff. Adding the corners is not difficult.
mowog1 Avatar
1969 MG MGC "Vicky"
In reply to # 3627628 by fast-MG.com Remove steering rack first. Then the suspension corners. Then the X-member. Assemble to the car in reverse order. Bare X-member is easier to bolt up to the car without all the other stuff. Adding the corners is not difficult.
I concur.....
But.....
When I removed this rack, it was to replace it with a FastCars unit....hence I did not disassemble it. Note that the steering rack is lying on top of the crossmember in the picture that I posted.
mowog1@aol.com
okephoto Avatar
okephoto Kevin Oke
And I wonder why my back hurts!
In reply to # 3627589 by mowog1 The crossmember that I removed from my 1974-1/2 MGB/GT...with all ancillaries attached....weighed in at #180.
okephoto Avatar
okephoto Kevin Oke
Hi Bill,
Yeah, the blaster is great. I'm blasting everything in sight. What a weird addiction! Cherie's gardening tools, benches, whatever. I measured the coils and they're within spec so just repainted them, time will tell I guess.
In reply to # 3627610 by Bill Hibberd Looking pretty sweet there Kevin. Good to see that you are getting good use out of your new blaster. Are those new coils? If so, which ones did you go for?
jewar Avatar
jewar Silver Member John Warlimont
Abbotsford, BC, Canada   CAN
I carried one the other day without the spindles or rotors and had no problem by myself. Leave the sway bar attached it makes it a lot easier to pickup.
John
dickstag Avatar
dickstag Gold Member Richard Stagnone
Holbrook, MA, USA   USA
1966 MG MGB "Unknown MGB"
1973 MG MGB "Mellow Yellow"
1974 MG MGB MkII "Ms Violet"
I like the red springs with the black front end components. Did you paint them red or did they come in red new ?
Is that the stock engine paint red ?
My new springs are black. Got me thinking about applying a coat of red (the Rustolium red). Further down the rabbit hole I go.
