I’m insulating my garage!
Jeff in Iowa Avatar
Jeff in Iowa Jeffrey J
Iowa City, IA, USA   USA
1970 MG MGB
Going with 1/2” OSB on the walls. Plan to install an electric shop heater and an A/C unit.
55B9B984-65EF-4B28-BAE3-CE47946123AA.jpeg    31 KB
NOHOME P P
O, ON, Canada   CAN
I would recommend the spray foam insulation. Does an amazing job of sealing the shop and keeps the noise from the neighbors.
Mitchman2 Avatar
Mitchman2 Mitchell Andrus
Mills River, NC, USA   USA
'bout time. Having a comfortable shop changes your whole attitude toward the hobby.
'30 Model A Ford
'48 MGTC
'58 MGA
'58 MGA
46er Avatar
46er Ralph K
Coastal, NJ, USA   USA
In reply to # 3627071 by Jeff in Iowa Going with 1/2” OSB on the walls. Plan to install an electric shop heater and an A/C unit.
OSB as insulation? Or did I misread something? I used 2 inch Pink Panther R10 foam boards between the studs, glued in place. Nice and cozy with a Heater Buddy. One cutting and gluing, one putting in place, took one day.
balloonfoot Avatar
balloonfoot Gold Member Lloyd Faust
Southlake, TX, USA   USA
Having grown up in northern Minnesota, my advice would be to install a drop ceiling. Otherwise it will be 80F up there and 40F down by the floor.
Jeff in Iowa Avatar
1970 MG MGB
OSB over 3.5” batts on walls and 1” foil board over the batts in the ceiling. I know spray on is great but trying to keep costs down. I like the open rafters and will put an old ceiling fan up in the peak.
Defender405 Avatar
Defender405 Silver Member Chris B.
Des Moines, IA, USA   USA
1975 MG MGB
Wish I had done the AC in mine. Having a toasty warm garage sure makes things nicer in the winter.
Chris AKA "Defender405"
1975 MGB
1979 Porsche 924
1999 Porsche 996
1987 Nissan 300ZX
bleteaches6 Avatar
Bonney Lake, WA, USA   USA
When I built my shop I used r 19 bats in the walls, I think r 23 in the ceiling. The shop now stays comfortable in the winter and cool in the summer here in the NW.
IMG_1123.JPG    49.3 KB
BusyB Platinum Member Sherman Bird
Houston, TX, USA   USA
1978 MG MGB MkIV "Jerzy"
Living in the subtropic climes of Houston, I planned my shop for very good insulation, a dehumidifier, and an A/C unit. The metal building is 45 feet by 25 feet with a 14 foot floor to center roof beam. My A/C unit is a 25000 BTU window unit that, combined with a couple of fans, does a great job of cooling me and my cars in the heat of the day! Dealing with cold here is not much of a problem. The heat, with 90+ % humidity and 110 degree heat indices, can and will KILL, especially a guy like me with CHF (congestive heart failure). Good for you climate controlling your garage!
dcasko1950 Gold Member Dana Casko
Deerfield, NH, USA   USA
Give some thought to a mini-split that will cool and heat.
1980 MGB LE, 1976 MGB Roadster, 1980 TR7
HiPowerShooter Avatar
Yep...
If not, at least install a couple of ceiling fans to keep that air moving and not rising and staying up high.
I just moved to a new house and one of the first things I did was to get a used furnace for the garage. A friend of mine owns an HVAC business and will keep the good units he tears out of homes to sell/give away to people to use as either garage units or for cabins etc...
I wouldn't go electric....heating a garage will break the bank.
If you don't already have a unit, look on CL. You can pick them up pretty cheap many times. If not, call around to some of your local HVAC contractors and see if they've got any older working units in their "scrap" pile. Mine will heat up a 3 car garage 20 deg in about 20 min. It's about 25 years old so although "old" it's still more efficient than most portable heaters.
Just plumb in the gas/propane, cut two holes in the wall and off you go.
In reply to # 3627107 by balloonfoot Having grown up in northern Minnesota, my advice would be to install a drop ceiling. Otherwise it will be 80F up there and 40F down by the floor.
Edited 1 time(s). Last edit at 2017-11-13 08:17 PM by HiPowerShooter.
20171113_200454[1].jpg    31.8 KB
rntanner Avatar
rntanner Silver Member Roger N. Tanner
Oxnard, CA, USA   USA
1970 MG MGB
Install the same insulation on the walls and ceiling that your house has.
My house has 5-1/2 inch fiberglass on the ceiling and 3-1/2 inch fiberglass on the walls in California and the previous house in Texas.
Roger N. Tanner, Professional Engineer, Retired
Roger N. Tanner
rocannon Avatar
1967 MG MGB GT "GT From Hell"
Remember the vapor barrier on interior of walls and ceilings
TANSTAAFL !
74GTBob Avatar
74GTBob Bob Riebli
Ephrata, WA, USA   USA
1970 MG MGB GT
1974 MG MGB GT
Looking at your picture, can not tell if you already have your batt insulation installed. If you do not and have 6" walls, R-19 does a much better job for not much more money. Also if you use foam board and faced batt insulation you may have a condensation problem. There are at least 3 different types of foam boards. Also in my area 7/16" OSB is cheaper and does the same job.. We do not sell 1/2" in our area. I am semi retired and work in a lumber-plumbing-hardware store. I sell lots of insulation and OSB every day. We also sell and install shops. If you have any questions about insulation, PM me, and I will ask my insulation salesman and get back to you.
melbaver Avatar
1968 MG MGB "Moneypit"
Hey Welcome Back Roger, good to see you posting again.
Chris Howells
1973 MG MGB Racecar
