LITTLE GREEN WIRE
LITTLE GREEN WIRE
  This topic is about my 1979 MG MGB MkIV
peter8004 Avatar
peter8004 Peter Dhama
Thornhill, ON, Canada   CAN
1973 MG MGB "4th Time"
1979 MG MGB MkIV
Gents, i just picked up this LE... Gorgeous all original 79. Number 244 of 250. Anyway, I had one of these brand new and sold it years ago. Since, I have had my 73 which I sold after 20 odd years. Now the question. I dont ever recall a wire like this on my previous car. It attached to the back of the carb... any thoughts.
DSCN0437.JPG    80.2 KB
DSCN0436.JPG    64.8 KB
DSCN0438.JPG    70.7 KB
mowog1 Avatar
Saint Joseph, IL, USA   USA
1969 MG MGC "Vicky"
1972 MG MGB "Mallard"
Induction heater wire.
mowog1@aol.com
mgbmac Avatar
mgbmac Silver Member James Patrick
Darien, CT, USA   USA
Peter,
That green wire attaches to a square block heater that is supposed to work in cold weather. I believe John Twist has a video regarding it's use and usefulness. It tends to crack and can be a source of vacuum leaks. I replaced mine with a solid piece from VB. Have fun, Jim
peter8004 Avatar
1979 MG MGB MkIV
i followed the wire to a box just under the fuse box... looks like a relay of some kind with two prongs. one of which the green wire is attached to.
rocannon Avatar
1967 MG MGB GT "GT From Hell"
You have some tracing to do. See attached.
In reply to # 3626716 by peter8004 i followed the wire to a box just under the fuse box... looks like a relay of some kind with two prongs. one of which the green wire is attached to.
TANSTAAFL !
0178B539-2C43-4E3D-87F8-DCF97D71E49A.jpeg    66.7 KB
course2kid Jeffrey Johnson
1979 MG MGB "Lucy (Lucifer)"
As others noted, it goes to the induction heater. The cylindrical part with a domed end is a thermal switch that closes below a certain temperature (I don't recall what temperature, but, IIRC, it's a ways below freezing. When it closes, current flows through a heater coil that warms the intake air/fuel mixture entering the intake manifold.
It sounds like the PO of your car added a relay in series with the heater.
Edited 1 time(s). Last edit at 2017-11-13 07:05 PM by course2kid.
BumbleB74 Avatar
BumbleB74 William Milholen
wow....looks like you bought a time capsule!
1973 MG C Type Midget
