Why you shouldn't split your calipers(and why I do anyways)
converse212 Avatar
converse212 Eric Morgan
Tucker, GA, USA   USA
1958 MG MGA
1970 MG MGB "Daily Driver"
1970 MG MGB GT "Rusty"
1971 MG MGB GT    & more
I rebuilt a new set of calipers for the B today, as I've been fighting a nasty brake squeal and decided it was time anyhow. When I build calipers, I ALWAYS split the halves, against the recommendations of Moss and the Factory Service Manual, as I don't really see an effective way to clean the caliper as much as I like to clean them without splitting the halves. Well, that's not quite true. Moss says not to split them...the FSM says not to reuse the bolts which hold the caliper halves together.
There's been much discussion over the years about this issue, and by and large people have summarily ignored the FSM, stating the reason for not reusing the bolts is that they are designed to stretch when they reach the proper torque and this is the reason they shouldn't be reused.
In actuality, the reason they should not be reused is that they have a locking device on the threads that holds the bolts in place. The locking section is a slightly discolored circle near the end of the bolt in the photo below. This is similar to never using nylock nuts twice...good practice, but in reality best left up to judgement.
So, in summary, there is a reason the factory said not to reuse bolts, it is not that the bolts stretch, and I reused mine anyways and haven't died due to caliper failure.
Daily driving a '71 MGB
Resurrecting a '58 MGA
IMG_0152.jpg    40.2 KB
33EJB Avatar
33EJB Tim C
LS, Eastern Ontario, Canada   CAN
That "locking device" looks just like a dab of threadlocker to me.
RAY 67 TOURER Avatar
RAY 67 TOURER Ray Marloff
Fort Bragg, CA, USA   USA
1967 MG MGB "My Girl"
X 2. RAY
converse212 Avatar
Tucker, GA, USA   USA
1958 MG MGA
In reply to # 3626083 by 33EJB That "locking device" looks just like a dab of threadlocker to me.
Have you ever taken apart a bolt that was put in with thread locker? It smears all over the threads as the bolt is screwed in. Show me a dab of thread locker on a bolt that's been in situ for 40 years and then removed with an impact gun and I'll eat my hat.
This is most definitely not thread locker. It's a bolt like THESE, similar concept to nylock nuts but applied on the male threads.
33EJB Avatar
33EJB Tim C
In reply to # 3626098 by converse212
Have you ever seen a bolt that has had a dab of threadlocker applied before it's been screwed in with an impact gun and in situ for 40 years?
That's what I'm talking about. No hat-eating required.
Tucson, AZ, USA   USA
1967 MG MGB
1967 MG MGB GT
1971 MG MGB GT
This is 50 year old technology. Newer vehicle caliper bolts use what looks like blue threadlocker from the manufacturer. If it is good enough for my Mustang Gt, it is probably acceptable for my MGB. All the calipers I have split have needed new O rings from deterioration. I always use new caliper bolts when available.
converse212 Avatar
Tucker, GA, USA   USA
1958 MG MGA
In reply to # 3626106 by 33EJB
Ah, I understand. Those bolts are exactly as they were removed from the caliper, I had done nothing to them besides clean the threads. No threadlocker applied at any point in the process
Boris67MGB Richard Boris
Kings Park. NY 11754, USA   USA
1967 MG MGB
Not sure where the notion that Lockheed didn't want the calipers split? Since they use to sell a caliper overhaul kit with new bolts and the internal fluid seal. You can find these NOS Lockheed kits periodically on e-bay.
1967 MG MGB
"Not sure where the notion that Lockheed didn't want the calipers split?"
Maybe this which debunks the notion.
Basil Adams Avatar
I was always told not to split the halves because there were no o-rings for that fluid passage. I found some NOS ones in a buyout about 15 years ago and "loaned" a few to a supplier. They had them remade to exacting standards and thanked me with a bag of 100 of them smiling smiley Since then, everyone can get them and the reason not to split has vaporized. As for bolts, I always use new ones and a dab of blue loctite and have never had an issue. Nowadays, new calipers are so inexpensive that it's hardly worth rebuilding! Basil 707.762.0974 basiladams@yahoo.com
Basil C. Adams
1956 MGA Coupe (Show Car)
1957 MGA Roadster (Driver)
1958 MGA Coupe (Racecar)
1959 MGA Coupe (unrestored)
1960 MGA Coupe (unrestored)
1960 MGA Roadster (Driver)
MKIII Elva Courier (E1056)
1967 427 Cobra
1972 Alfa Romeo Montreal
A coupla late MGBs
1960 Austin Healy BN7
More Cars than Brains
ddubois Avatar
Bremerton, WA, USA   USA
Quote: As for bolts, I always use new ones
There in lies the reason not to split the calipers - If the correct bolts are used in rebuilding the calipers, just like using new head bolts whenever the engine head is reinstalled. Yes, the used bolts may not have been over stretched, but I would certainly bet my life on it.
Dave DuBois
1953 MGTD
1966 MGB
OzDave Avatar
OzDave Dave Barton
London, ON, Canada   CAN
In reply to # 3626170 by MGB567
Nice article Barrie. It says "torque to a reasonable spec". I'd be interested to hear a few thoughts on what that number should be as I've yet to come across that spec anywhere I've looked.
barry s Avatar
Alexandria, VA, USA   USA
1972 MG MGB GT
1976 Triumph TR6
Bentley states torque of 35.5 - 37 lb.ft. (Section M6)
the omega man Avatar
the omega man phil wilkins
Fit new calipers and forget about it.
