Vent control question
Jeff in Iowa Avatar
Jeff in Iowa Jeffrey J
Iowa City, IA, USA   USA
1970 MG MGB
My hood vent is impossible to open or close while seated. I rigged up a handle that hangs down so now I can manage to open and close it while driving without opening the door and reaching up there on my knees. Did MGBs originally have a handle of some sort that my ‘70 was missing?
focodave Avatar
focodave Gold Member Dave Baker
Fort Collins, CO, USA   USA
1970 MG MGB GT "Gidget"
1980 Fiat 124 Spider 2000
Jeff,
I'm not sure if this will make you feel any better, but my '70 is exactly the same as yours.
I have to get on my knees to be able to see and grasp the handle to operate the vent.
If I tried to operate it from the driver's seat, I would need to have 2 wrists on one arm in order to get my hand at the proper angle.confused smiley
Dave
Yes - most often the question here is "what's this white knob do?" and the answer is "opens the fresh air vent".
Well if you think you need two wrists spare a thought for us with the steering wheel on the correct side tongue sticking out smiley
vent7.jpg    6 KB
Jeff in Iowa Avatar
1970 MG MGB
Then it was rinky dink from the factory. Not as greivous as the heater control valve I suppose.
Tucson, AZ, USA   USA
1967 MG MGB
1967 MG MGB GT
1971 MG MGB GT
Use the one from a RB car that has the longer arm. Check the buy, sell, trade forum if you want the one that will work for you.
mgbanthony Avatar
Gananoque, ON, Canada   CAN
1962 MG MGB
1962 MG MGB
1968 MG MGB MkII ~ For Sale ! ~
1970 MG MGB GT    & more
The knob on the 70 is black....
Try lubricating the hinges and the spring loaded roller. Mine works ok.
melbaver Avatar
1968 MG MGB "Moneypit"
Thye spring loaded roller needs to be well lubricated and not binding anywhere. Then you simply pull backwards on the lever which is on the left side of the vent. Should be a doddle for LHD cars.
Chris Howells
Edited 1 time(s). Last edit at 2017-11-13 05:07 AM by melbaver.
"Then you simply pull backwards on the lever which is on the right side of the vent"
You mean:
"Then you simply pull backwards on the lever which is on the left side of the vent"
melbaver Avatar
In reply to # 3626629 by MGB567 "Then you simply pull backwards on the lever which is on the right side of the vent"
You mean:
Fixed
Chris Howells
Jeff in Iowa Avatar
1970 MG MGB
My custom high tech hardware store vent control.
B4B8B3E6-F6D4-4B87-B8DE-A037E4700578.jpeg    38.1 KB
