Whats the difference of DOT 3 vs DOT 4 Brake Fluid
RestorerMG Avatar
RestorerMG Silver Member Bill Schultz
SOUTH HADLEY, MA, USA   USA
Installing a new slave cylinder for clutch, Changed out out Yoke, pressure plate, clutch plate already. 20/50 in transmission.
All info points to DOT 4 for the system. Whats the difference from DOT 3?
Renewing all of brake system also, Shoes, drums, disk, pads,lines, etc... Should I use DOT 4 also?
4 is compatible with 3
Higher BP
You can use either
Fresno, Ca, USA   USA
About $2.50
Aphyle2012 Avatar
Aphyle2012 Silver Member Eric Pyle
Shenandoah Valley, VA, USA   USA
DOT 3 is bad for natural rubber seals. DOT 4 is not. First-hand experience with having seals blow coming to a T-intersection.
DOT 3 is nearly everywhere. DOT 4 is not.
DOT 3 is cheaper. DOT 4 is...not.
Both absorb water. DOT 5 does not.
tahoe36c Avatar
tahoe36c Paul Hruza
Panama City, FL, USA   USA
1972 MG MGB GT "Tiny Dancer"
2002 Harley-Davidson Dyna
Bill,
Now that you have heard all the scientific data and other blabber... moon The "right now answer" is use DOT 4. Best Choice. thumbs up
Paul
SCE Avatar
SCE Sven Erichsen
Renton, Washington, USA   USA
1973 MG MGB "Betty"
DOT4 is one dot better.
ingoldsb Avatar
DOT 4 has a higher boiling temperature, but shorter lifespan (due to higher moisture absorption) than DOT 3. At least, that is what my reading indicated. Practically, I've never noticed any real difference. They can be mixed.
Terry Ingoldsby
terry.ingoldsby@DCExperts.com
Grahamhaber Avatar
Grahamhaber Graham Haber
Dingman Township. Pa., NYC,New York, USA   USA
The chart attached shows the difference it is the rated boiling points, although you can buy products sold as DOT 3 claiming 450 degree boiling point. But those are the department of transportation minimum requirements for the rating. except for 5 they are all glycol based with more borate esters in 4 & 5.1 to increase boiling temp. The most important thing is to charge your fluid every 1-2 years as it absorbs water lowering your boiling point and corroding your broke system from the inside. Wet boiling point refers to performance after it has been in your system a year + and has absorbed water from the air.
Edited 1 time(s). Last edit at 2017-10-13 12:25 AM by Grahamhaber.
Screen Shot 2017-10-13 at 1.13.46 AM.jpg    23.5 KB
lgorg Avatar
lgorg Larry Gorg
Renton, WA, USA   USA
1966 MG MGB "Robbie"
You received the short answers above. For the longer answer, please refer to Brake Fluid Comparison Chart. There are 83 fluids listed in the comparisons. The author is into Porsche and Lamborghini, but the data is still good for MG's. Below the chart is an explanation of brake fluids that is an interesting read by itself. Like batteries that are made by Johnson Controls with many labels, brake fluid is also manufactured by one company that slaps different labels on them.
The recommended changeover is different too (as well as BP) - I'm sure Google knows but if you can't find it just go read the back of each bottle.
