rear shock
rear shock
  This topic is about my 1969 MG MGB
Dburdick Avatar
Dburdick Silver Member Douglas Burdick
Winnsboro, SC, USA   USA
1957 MG MGA "Mary"
1969 MG MGB "Doubtfire"
1969 MG MGB "Mrs. Doubtfire"
1969 MG MGB "Mrs Doubtfire"    & more
So I'm trying to install the rebound straps and rear shocks. I have the axle sitting on jack stands. the rebound strap Moss sold me, 267-565, for a 69 mgb, wont quite reach. also, do i tighten the link bolts to the freshly rebuilt rear shock, or leave them loose and tighten them after the wheels are on with the car on the ground?
RAY 67 TOURER Avatar
RAY 67 TOURER Ray Marloff
Fort Bragg, CA, USA   USA
1967 MG MGB "My Girl"
Have you recently replaced the springs also? New springs often need extra weight, in the trunk, to fasten the straps. You can tighten the shock bolts now, however. RAY
Defender405 Avatar
Defender405 Silver Member Chris B.
Des Moines, IA, USA   USA
1975 MG MGB
Also depends on how you have it jacked up. If you have the suspension hanging with jack stands under the body then no straps will be long enough, put a jack under the diff and load the suspension some and the straps should fit. With the Moss straps you cannot hang the suspension from them though, they won't take the weight and will snap.
Chris AKA "Defender405"
1975 MGB
1979 Porsche 924
1999 Porsche 996
1987 Nissan 300ZX
Dburdick Avatar
1957 MG MGA "Mary"
In reply to # 3608419 by RAY 67 TOURER Have you recently replaced the springs also? New springs often need extra weight, in the trunk, to fasten the straps. You can tighten the shock bolts now, however. RAY
Nope. all the springs are original. for now.
Dburdick Avatar
1957 MG MGA "Mary"
In reply to # 3608492 by Defender405 Also depends on how you have it jacked up. If you have the suspension hanging with jack stands under the body then no straps will be long enough, put a jack under the diff and load the suspension some and the straps should fit. With the Moss straps you cannot hang the suspension from them though, they won't take the weight and will snap.
no, the rear axle is sitting on the jack stands. the weight of the body isn't enough, especially with the shocks hooked up. Guess I'll unhook the shocks, put weight in the body,then hopefully attach the straps, followed by the shocks.
" the rebound strap Moss sold me, 267-565, for a 69 mgb, wont quite reach. "
Too late now but should you break them next time get Strapping Lads' - I thought everyone (other than those being an absolute purist) got those rather than the rubber rubbish.
course2kid Jeffrey Johnson
1979 MG MGB "Lucy (Lucifer)"
There is no need to disconnect the shocks because they are just dampers and do not "push" the axle downward. I'd suggest you either throw some weight into the truck (sand bags, tool boxes, or whatever) and/or jack up one side of the axle to get more weight on that side (and, of course raise the jack stand on that side for safety).
I did see a post within the last week where the author said the straps they got from Moss were shorter than some others that they subsequently purchased elsewhere (try a search). As I recall, the poster said that with the axle hanging by the shocks, the distance between the centers of the strap mounting points was 10.5", his Moss straps were 8.0" and were expected to stretch 0.5" under the weight of the axle. So, by his reconing, their was 2" of unuseable shock travel. So he got some 9" straps to reduce this to only 1" of unused travel (you do need some in order for the straps to protect the shocks from bottoming out).
Dburdick Avatar
1957 MG MGA "Mary"
In reply to # 3608748 by course2kid There is no need to disconnect the shocks because they are just dampers and do not "push" the axle downward. I'd suggest you either throw some weight into the truck (sand bags, tool boxes, or whatever) and/or jack up one side of the axle to get more weight on that side (and, of course raise the jack stand on that side for safety).
Well, I managed to get them installed by doing as suggested and using weight to bring them to their mounting point, but they feel a bit taunt. I thought there should be more play?
barry s Avatar
Alexandria, VA, USA   USA
1972 MG MGB GT
1976 Triumph TR6
Seems to me that having the rebound straps in tension when the car is sitting on the ground is just wrong. If nothing else, the life of the straps will be diminished.
Tell destroy themselves in short order anyway.sad smiley
Order some from the Lad thumbs up
1970 MG MGB V8 Conversion
