1979 mgb panel light rheostat
Drew Ledet Andrew Ledet
Hernando, MS, USA   USA
Hello, i have just recieved my panel light switch, and on my wiring diagram, it says that there should be 4 wires hooked up to it, 3 red and white wires and a brown wire. If anyone could gelp me locare these, it would be great. Thank you
RAY 67 TOURER Avatar
RAY 67 TOURER Ray Marloff
Fort Bragg, CA, USA   USA
1967 MG MGB "My Girl"
Behind the dash, above the steering column. RAY
Ex-Calif Avatar
Ex-Calif Gold Member Dan D
Cincinnati, Ohio, USA   USA
1977 MG MGB "Red Betty"
2012 Jeep Liberty "Tank"
2014 Hyundai Accent "Skate"
Shouldn't that be 3 red/white and a red/green?
That is what I had thought but when I plugged them all in to the spade connetors, nothing happened
HardlySlept Avatar
HardlySlept Chris Gatti
New Berlin, New York, USA   USA
1980 MG MGB "Blythe"
With the dimmer out of the circuit, and the wires not connected to anything, are the panel lights off when the parking lights/headlights are on? If they are off, then it should be a matter of getting the wires correctly connected to the dimmer. Red/green wire to one terminal and the three red/white wires to the other terminal.
If that's not working, test for power at the Red/green wire when the parking lights/headlights are on. Should be 12 volts +/- a bit. You can connect the Red/green directly to the red/white wires, bypassing the dimmer, and the panel lights should work when the parking lights/headlights are on.
If the panel lights are on with the dimmer out of the circuit, there could be another wire that someone added that is powering the panel lamps.
dimmer.jpg    57.1 KB
riley1489 Gold Member Bruce H
A Red/Green wire feeds the rheostat from the headlamp switch,
the photo below shows the output of the rheostat to the sub harness.
As Dan writes, the later model you have should have quantity 3 Red/White wires versus the 1 R/W shown below.
Principle remains.
Check your ego Amigo!
Edited 1 time(s). Last edit at 2017-10-12 07:19 AM by riley1489.
BH_dash sub harness1.JPG    28.9 KB
Ok, i will try that out now, thanks
It works, thank you very much sir
