Compression results for my 1966 MGB
  This topic is about my 1966 MG MGB
CADDMAN04 J.P. Gauthier
Toronto, Ontario, Canada   CAN
1966 MG MGB
I have just completed my compression test on my MGB. It is 162(1) 161(2) 160 (3) 162 (4) . Are these results ok? I have a problem with my 3rd spark plug. It is always black, no oil just carbon, number 1, 2, and 4 are fine. I wonder was could be the problem, valves, or sticky ring? Could anybody please let me know if the compression test results are good , and how to solve the problem with the dirty number 3 cylinder plug.
Thanks
J.P. Gauthier
Compression is fine.
What plugs and gap BP6ES @ 25THO
Carbs might be slightly rich
Lean it out a tad
fast-MG.com Avatar
What RobC said. Plus, verify carb balance both at idle and off idle before adjusting mixture.smoking smiley
1966 MG MGB
Thanks, everyone, the plugs are the spec Champion plugs. I will check the plug gap. The carbs were recently tuned with a vacuum gauge to sync the intake and idle. The mixture was set to spec appears to be running a bit rich, I can lean it out a bit to see if this helps.
HiPowerShooter Avatar
You should also see somewhere between 24-30 mpg depending on your city/highway driving under normal conditions. IF it's significantly lower...you're definitely running rich.
nickj Avatar
1970 MG MGB GT
A picture of the #3 plug might help. If it's black from not firing, could be the plug. If it's crusty, could be a valve guide or seal.
I'd lean it out and try NGK BP6ES
Gappend correctly
Champions no moresad smiley
ClayJ Avatar
Mt. Olive, MS, USA   USA
That plug, plug-wire, cap or rotor might not be firing consistently on that cylinder. Try swapping plugs to see if the probably follows the plug, if not do the same thing with the plug-wire, if the probably is still on #3, replace the rotor and cap. Also inspect the dizzy shaft to ensure it is not bent.
Ex-Calif Avatar
Ex-Calif Gold Member Dan D
Cincinnati, Ohio, USA   USA
1977 MG MGB "Red Betty"
2012 Jeep Liberty "Tank"
2014 Hyundai Accent "Skate"
Intake valve guide seal would be myvote for one plug only being blackened.
It would be interesting to see a photo of all the 4 plugs.
In reply to # 3591263 by nickj A picture of the #3 plug might help. If it's black from not firing, could be the plug. If it's crusty, could be a valve guide or seal.
