Anyone make a clutch stop?
  This topic is about my 1970 MG MGB GT
nzimmers Avatar
nzimmers Gold Member Neal Z
Renton, WA, USA   USA
Hi all,
my clutch pedal fully engages about 1/3 of the way in - I'd like to make a clutch pedal stop at 1/2 - anyone do this before? any pictures?
thanks in advance!
The clutch is self adjusting
Don't defeat it with a stop
Or at the very least adjust it at the pushrod.
billymgb1000 Avatar
billymgb1000 Silver Member william gaulin
harrisville, harrisville RI, USA   USA
1974 MG MGB V8 Conversion "Sweet Thing"
You should be able to adjust the clutch so it disengages lower so the floor itself will be the stop. don't put a stop you will lose your adjustment.
"Or at the very least adjust it at the pushrod."
Curious how you do that with the B's stock M/C? I understand when the pushrod is threaded and there's a nut to adjust.
I thought there was a self imposed stop provided by the pedal box itself. FWIW when we built my triple M/C pedal box we couldn't get full travel on the Wilwood threaded pushrod before hitting the pedal box frame. We achieved it by placing a spacer between the M/C and the pedal box face.
Edited 1 time(s). Last edit at 2017-09-13 01:34 AM by MGB567.
Donthuis Avatar
Donthuis Don van Riet
The only reason for changing the clutch self-adjusting feature is when you do NOT use a carbon TO bearing, but a roller bearing. It prevents constant engagement of the roller bearing which in some, rare? cases is damaged by this. However lots of people just let their roller bearing be engaged permanently and do not seem the worse for it. Adrian and I are in the adjustment group BTW smileys with beer
B-racer Avatar
B-racer Jeff Schlemmer
Shakopee, Minnesota, USA   USA
2014 Dodge Charger
MG or after market transmission, clutch master, and slave? Mix and match parts with different sizes and it'll work differently. For example, I run a Datsun slave, MGB hose, and Wilwood master but they're sized to operate like original with a factory OD trans. A smaller master or a larger slave will give you more pedal travel with less clutch travel, if you go aftermarket.
jeff@advanceddistributors.com
Jeff,
Can you explain how an overdrive gearbox fits into the mix?
In reply to # 3591131 by B-racer MG or after market transmission, clutch master, and slave? Mix and match parts with different sizes and it'll work differently. For example, I run a Datsun slave, MGB hose, and Wilwood master but they're sized to operate like original with a factory OD trans. A smaller master or a larger slave will give you more pedal travel with less clutch travel, if you go aftermarket.
Edited 1 time(s). Last edit at 2017-09-13 01:42 PM by dickmoritz.
RAY 67 TOURER Avatar
RAY 67 TOURER Ray Marloff
Fort Bragg, CA, USA   USA
1967 MG MGB "My Girl"
I've installed just such a system on my '67 B. This allows me to set the clutch pedal wherever I like. The kit was designed by Doug Jackson at MGBMGA.com. It mounts to the transmission underneath the slave cylinder and is adjustable. RAY
