SU AZX 1307 or 1331
OldEvo Silver Member Jeff Clark
Weems, Virginia, USA   USA
I want to put a points SU fuel pump back in my 64 B. It's a November 1964 car and it appears that the pump changed sometime earlier in that model year. I see references to "up to #44438" and "from #44439". Is that a body number or something else?
The NAPA pump that was in it runs constantly and annoys me. Yes, I am easily annoyed.
jjonns74 Avatar
Indianapolis, Indiana, USA   USA
1974 MG MGB "Athena"
1974 MG MGB "Apollo"
Those #s refer to the VIN
My Apollo's VIN = GHN5UE346515G
Application would show ......346515
Edited 1 time(s). Last edit at 2017-09-12 09:39 PM by jjonns74.
Basil Adams Avatar
A 1964 and before fuel pump has male fittings sticking out from it. The 5 main pump has female fittings for banjo bolts. Which does yours have? Let me know if I can help. Thanks. Basil 707.762.0974 basiladams@yahoo.com
Basil C. Adams
1956 MGA Coupe (Show Car)
1957 MGA Roadster (Driver)
1958 MGA Coupe (Racecar)
1959 MGA Coupe (unrestored)
1960 MGA Coupe (unrestored)
1960 MGA Roadster (Driver)
MKIII Elva Courier (E1056)
1967 427 Cobra
1972 Alfa Romeo Montreal
A coupla late MGBs
1960 Austin Healy BN7
More Cars than Brains
If you don't know to what Basil's referring look at #6 and #33 below - #6 is 1331 pump
fuel pump 1.jpg    30.7 KB
When I got the car the original pump was gone, replaced with a NAPA pump and regulator. Of course all the fuel lines have been hacked off so I will need to adapt anything I get. This is a late 64 model with a 5 main engine.
Are the different pump models just a matter of different hose fittings? I can probably find compression fittings at the local hardware store. Banjo bolts, not likely.
riley1489 Gold Member Bruce H
Jeff,
Local hardware fitting will not fit the BSP threads of the SU pump body.
Put a request on the BST forum for a previously loved SU pump. Then send it to Dave Dubois for a refresh.
Doing this you will be guaranteed to get a fit on the car that works without modifications, funky hoses, superfluous clamps etc.
Enjoy trouble free and quiet drives! grinning smiley
Check your ego Amigo!
Bruce, just found a used 1307 on eBay and ordered it. I also ordered a couple banjo bolts and hose barbs from englishparts.com. I post the results.
Jeff
Good on ya Jeff. smileys with beer
Install this correctly, both bracket/grommet and orientation, (bowler hat shaped chamber pointing north) loose the pressure regulator, install new correct size fuel hoses, and a filter just before the carburetors under the bonnet, and you will be good to go.
BH_bracket-SU.JPG    16.7 KB
BH_SU orientation - 2.jpg    47.8 KB
ozieagle Avatar
1958 Wolseley 1500 "Wooly"
1966 MG MGB "Bl**dy B"
Jeff,
FWIW worth I rescued my SU pump, when the threads stripped in the body, as in the attached article.
Herb
I actually wound up doing both ports.
Edited 1 time(s). Last edit at 2017-09-13 02:30 PM by ozieagle.
Saga 31 pump fittings.pdf    295 KB
astbury Avatar
astbury Gold Member Mark Astbury
Rye, NY, USA   USA
1966 MG MGB "Megan B"
Jeff - some info toward the end of the following thread about trouble I had with the new banjo bolts and the hole being too close to the bolt head. You may not have this problem, but I couldn't get them to seal. Be interested to see a photo of the bolts you receive.
http://www.mgexp.com/phorum/read.php?1,2948306
Edited 1 time(s). Last edit at 2017-09-13 05:00 PM by astbury.
"and a filter just before the carburetors under the bonnet"
Mmm given the Factory didn't think it necessary why do you - unless it's to do with crap in the fuel including breakdown of the fuel line (by using "rubber" ) caused by today's fuel recipes?
PS I had an inline filter but removed it as I couldn't get a decent seal with my Speedflow100 line.
Edit - bloody smileys!
Edited 1 time(s). Last edit at 2017-09-13 07:03 PM by MGB567.
In reply to # 3591490 by MGB567 "and a filter just before the carburetors under the bonnet"
Barrie
A rather odd query, and I guess to me?
The factory did install a fuel filter just before the carburetors, why do you think, "the Factory didn't think it necessary" ? confused smiley
Factory parts list call up a BMC/BL fuel filter part number.
Factory publications, workshop manual & driver handbook show this filter in place.
Many cars fitted with the predecessor to the HS type carburetor were fitted with H type carburetors that had a 'designed' filter at each float chamber inlet.
As well considering most of these cars have suspect fuel tanks and sit around more than they are driven an in line fuel filter installed just before the carburetors is common sense.
Carry on
Herb, nice fix. I think that may be better than banjo fittings. If I can't find decent washers I may go that route.
Herb, I just received the used SU pump I bought on eBay. Sure enough, a 3/8 NPT pipe plug fits perfectly. Your solution is going to save me a lot of time and trouble.smileys with beer
ozieagle Avatar
Glad to be of help.
If you wind up using two 90 deg hose tails, you will need to trim one back, so it can rotate past the other one.
Herb
