Cracked fuel pump
Cracked fuel pump
  This topic is about my 1972 MG MGB MkIII
jpmcleod3 Avatar
jpmcleod3 John Mcleod
Burt, MI, USA   USA
Day started great.
Fuel smell in the garage.
Looked under the B and screamed.
Thoughts on the replacement??
Thanks.
IMG_2842.JPG    44.8 KB
IMG_2844.JPG    33.2 KB
barry s Avatar
Alexandria, VA, USA   USA
1972 MG MGB GT
1976 Triumph TR6
Replace with genuine SU pump.
jpmcleod3 Avatar
Burt, MI, USA   USA
SU solid state or not??
33EJB Avatar
33EJB Tim C
LS, Eastern Ontario, Canada   CAN
The same thing happened to my plastic-bodied aftermarket fuel pump.
I replaced it with an electronic pump (no points), made in Germany - brand name escapes me - Hardi? maybe? Not a problem since, ~ 6 years or more.
Wachtmans Avatar
Wachtmans Wouter Strodijk
1974 MG MGB "The Bee"
1974 MG MGB MkIII "The Bee"
Yes, Hardi is the one to go for. Works like a champ.
Hardi, Germany.jpg    44.3 KB
jpmcleod3 Avatar
Burt, MI, USA   USA
Thanks for the advice.
Next task, find a supplier in the states.
Thanks again.
GaryDLowrie Avatar
GaryDLowrie Silver Member Gary Lowrie
Dewey, AZ, USA   USA
1971 MG MGB GT "The Green Dream"
1974 MG MGB "Pearl"
http://thebhive.com/131MGBfuelpumps.htm
https://www.bpnorthwest.com/fuel-pump-electronic-dual-polarity-banjo-mgb-65-to-80.html
http://www.ebay.com/itm/like/201586118562?chn=ps&dispItem=1
In reply to # 3589668 by jpmcleod3 Thanks for the advice.
Thanks again.
Edited 2 time(s). Last edit at 2017-09-10 02:50 PM by GaryDLowrie.
jpmcleod3 Avatar
Burt, MI, USA   USA
Thanks for the links.
Jeffs72MGB Avatar
Jeffs72MGB Jeff Strong
Eden, NY, USA   USA
Contact Basil Adams for your Hardi pump. That's where I got mine and I'm very happy with it and Basil.
Wachtmans Avatar
Beedapox Avatar
Beedapox Silver Member David Terry
Tomball, TX, USA   USA
1976 MG MGB "My Little Blue Friend"
X2. Bought my Hardi from Basil. Drop in and go.
In reply to # 3589680 by Jeffs72MGB Contact Basil Adams for your Hardi pump. That's where I got mine and I'm very happy with it and Basil.
1976 MGB Roadster with Factory Overdrive
Weber DGV / Pierce Manifold & Tourist Trophy SS Exhaust
Lucas 45D Distributor (No Vacuum Advance)with Allison Electronic Ignition & Champion N9YC Plugs
Original Brake MC (DOT5)
Replacement Lockheed Clutch MC and Slave (DOT5)
Hardi fuel pump
Aftermarket ejection seat
i AMS 4u Avatar
i AMS 4u alfred dawes
Grimesland, NC, USA   USA
1968 MG MGB GT "My First MGB-GT"
1969 MG MGB GT "My Second GT"
1969 MG MGC
1970 MG MGB GT "My Fourth MGB-GT"    & more
Wouter,
Your site appears to have great price, but from what I can read in the information it does not ship to US.
Too bad for some of us, but great for those on your side of the pond.
Al
Donthuis Avatar
Donthuis Don van Riet
Hardi it is, MOSS also resells them and these metal pumps are fully plug compatible with the traditional SU (washers at both sides of the banjo, electronic SU's have a seal on the pump side).
BTW I also renewed the hollow bolt after a few years, the Hardi just works on and on but the banjowashers leaked a bit: new bolt and washers and all is fine again for many years to come smiling bouncing smiley
PS Do not paint any pump, it is not necessary at all and may disturb the banjo junctions
In reply to # 3589617 by 33EJB The same thing happened to my plastic-bodied aftermarket fuel pump.
rocannon Avatar
1967 MG MGB GT "GT From Hell"
I bought a used SU pump off eBay, sent it to Monsieur Dubois, and got back a fully rebuilt/tested pump for just a bit less than a new SU pump. Included convert to solid state points and set to 2.5 psi.
Hardi would have been less, but I wanted an SU.
TANSTAAFL !
Edited 2 time(s). Last edit at 2017-09-12 11:30 AM by rocannon.
miatadon Avatar
miatadon Silver Member Don Scott
Calistoga, CA, USA   USA
I used to use those plastic pumps from NZ, and had the same issue of them cracking. I still have a few unused ones in boxes.
I know Mark Medynski and have bought new and rebuilt pumps from him. I recommend his products as he uses alcohol-resistant rubber so the pump will last.
https://www.sufuelpump.com/
