Rough running, low power in engine
  This topic is about my 1967 MG MGB
Banana Skin Avatar
Banana Skin Stewart C
West Hills, CA, USA   USA
Hi all,
Going to describe my rough running engine in the hope someone can diagnose for me.
Engine starts fine and I have the idle set to around 800rpm. Once the engine warms up the idle seems to drop and there is a loss of power when I drive. I can feather the throttle to compensate but at a traffic light without throttle management it will stall. If I set the carb idle higher when I stop at the light it's screaming. Any thoughts would be appreciated.
Stewart
Wachtmans Avatar
Wachtmans Wouter Strodijk
1974 MG MGB "The Bee"
1974 MG MGB MkIII "The Bee"
Might be a tired fuel pump......check, double check.
HiPowerShooter Avatar
Oshkosh, Wisconsin, USA   USA
If it's been awhile...rebuild/refresh your carbs or at least start from the beginning and dial them in again. It's fuel delivery.
RAY 67 TOURER Avatar
RAY 67 TOURER Ray Marloff
Fort Bragg, CA, USA   USA
1967 MG MGB "My Girl"
Have the throttle shafts ever been replaced in your carburetors? If not, you may be getting large vacuum leaks around the shafts. This causes the carburetors to function properly at one speed, and poorly at another. Impossible to balance then correctly. RAY
Rick Fawthrop Avatar
Seattle, WA, USA   USA
How many carbs do ou have?
Ex-Calif Avatar
Ex-Calif Gold Member Dan D
Cincinnati, Ohio, USA   USA
1977 MG MGB "Red Betty"
2012 Jeep Liberty "Tank"
2014 Hyundai Accent "Skate"
If your car "starts fine" and idles with no choke at first cold start of the day you are running too rich.
My cars need choke on first start and will need choke for at least 2-3 minutes or they will stall.
When warm they start with a click of the key and will idle at least 20 minutes (longest I have tried)
If it's a Weber please disregard...
Banana Skin Avatar
Thanks for the notes on this. I decided to get the carbs refurbished and sent them to Lawrie Alexander at British Sportscar Centre. He did a fantastic job and they're installed. Everything seemed good. The car idled perfectly around 850rpm with minimal adjustment. It wavered occasionally but nothing extreme so I took it for a drive. Temps rose quickly (unusual) and then the revs got stuck up at 1500 mark and would not drop. Climbing the hill to my house I lost power again. Is this a timing issue or fuel delivery? Distributer cap looks clean and the rotor arm too. I also noticed the timing marks are missing from the front of my engine, any ideas on how I can set timing without them ? Am I looking at rebuild of the Distributer ? I have new plugs already. Just wondering which direction to go next.
Thanks
barry s Avatar
Alexandria, VA, USA   USA
1972 MG MGB GT
1976 Triumph TR6
Whether carbs have been rebuilt or not, one still must tune them properly. Smooth running at idle is a poor measure of proper carb mixture. There is a pretty large range of rich/lean that will still allow a decent idle. Once under load is a whole different story. A carb rebuilder may set a set of carbs to the initial setting (in the tuning process) to allow starting the engine. Once mounted the carb mixture must be fine tuned. References to 'road tuning' mean assessing the car performance and adjusting the carb accordingly until proper acceleration is achieved. The final step is rebalancing the carbs and setting idle rpm.
BTW I agree with Dan on a likely rich mix.
Edited 1 time(s). Last edit at 2017-09-13 11:14 AM by barry s.
Read your plugs...they'll tell you what you need to know.
Too rich/Too lean and ensure equality among the four cylinders individually and two "banks" as primarily fed by each carb.
No book/spec will substitute for driving and road tuning.
I usually dial my advance all the way back when I set base timing so that I can easily roll in more on the road.
Ex-Calif Avatar
Pretty sure the timing marks on your 67 are on the bottom of the crank pulley (like mine)
PITA when doing timing but you get used to it.
If you don't have a Hayne's manual get one soon - it will help in things like this.
For timing here is what I have settled on.
- Turn the engine crank until the crank mark is aligned with 10* on the block mark.
- Make a new mark at 0*
- This now gives you a reference mark for 30* and means you don't need a dial back timing light
Start the engine and adjust idle screws until you get 3,000 RPM.
Adjust timing to about 32* for the HC engine - your new mark just past the 20* mark.
In reply to # 3591195 by Banana Skin I also noticed the timing marks are missing from the front of my engine, any ideas on how I can set timing without them ? Am I looking at rebuild of the Distributer ? I have new plugs already. Just wondering which direction to go next.
Thanks
1971 MG MGB MkII
