Thom's Nub issues!
L84DNR Luke Clement
Anchorage, AK, USA   USA
1969 MG MGB GT "L84DNR"
So it appears the neck on the bottom of the air intake that the drain tube attaches to has rotted away... see pics
I had to cut it in half to get it out of the passenger foot well heater vent and found that the metal part was still lodged inside the drain tube...
My question is what do I do now?
Is there a way to get inside that upper air intake with a step bit so i can drill it out and install a new fitting and then just run a hose out the bottom?
IMG_3206.JPG    40.4 KB
IMG_3207.JPG    31 KB
IMG_3208.JPG    22.8 KB
barry s Avatar
Alexandria, VA, USA   USA
1972 MG MGB GT
1976 Triumph TR6
You'd be smart to take a close look at the integrity of the fresh air box.
With a bit of effort you can reach 'Tom' from beneath the car. Not sure it would be possible to actually push a new one into place. You'd still have to install the clamp from the cockpit.
L84DNR Luke Clement
The nipple on the box is rotted off and stuck in the old hose...
How do you access the fresh air box?
barry s Avatar
1972 MG MGB GT
1976 Triumph TR6
Ouch!
Gary E Avatar
I know a good urologist that cn fit that..
"The nipple on the box is rotted off and stuck in the old hose. How do you access the fresh air box?"
So have you removed the chrome fresh air vent in front of the windscreen? If so or you do you should see a hole where the "nipple" (I prefer spigot) once was. So try to work out what diameter that is and cut a new spigot. Depending on how much rust you have there you'll need to attach that to a flat plate unless there's no rust in which case just give it a trumpet top. Then you drop it in with the underside of the plate glued up after first having cleaned up the flaky rust as best you can and painting with POR15. Once that's "gone off" you can attach another Tom's knob (if you can find one) or you could just attach a hose. If you make your spigot long enough you should be able to access the joining spot a little easier than OEM via the vent door. Others have questioned the need for the plenum. I'm doing this from a logic perspective only - I'm sure I missed a step so others can chime in.
Edited 2 time(s). Last edit at 2017-08-13 07:22 AM by MGB567.
Ex-Calif Avatar
Ex-Calif Gold Member Dan D
Cincinnati, OH, USA   USA
1977 MG MGB "Red Betty"
2012 Jeep Liberty "Tank"
2014 Hyundai Accent "Skate"
Without majorly disassembling the car Barrie's fix is as good as any I can think of. Sometimes "engineering" a fix is the path of least resistance. Just use a lot of common sense so that it "looks" right when it's done.
glbishop Avatar
glbishop Gary Bishop
Spring Hill, FL, USA   USA
Have you considered the car might have gender identity disorder.
arnolda Avatar
arnolda Arnold Adams
Vancouver, WA, USA   USA
Replacement drain tubes are now being carried by Brown & Gammons.
https://www.ukmgparts.com/product/mgb-midcat-12-submgb15-heater-assembly-valves-cables-controls/mgb-heater-drain-ahc321
Good luck with your spigot repair.
Arnold
L84DNR Luke Clement
So one thing I found after pulling off the chrome great, there's a deflector plate in there that blocks my view of the spigot location. Does this plate come out if so how?
barry s Avatar
1972 MG MGB GT
1976 Triumph TR6
I've been surprised that this has not been mentioned until now. I didn't since I figured that eventually you would remove the grill and see for yourself. Like everything else about this 'box', it is welded in place.
Aah so that plate's there on your '69 too as it is on my Mk1 but IIRC not on my GT - you can't see the spigot hole with a torch? AFAIK that plate can only be removed by cutting. In that case all I can suggest is removal of the various stuff in the way underneath including #55 so that will allow you to get at where the spigot was but you'll be repairing it from below. Or can you remove the heater - many say that's a PITA job - so you can gain access to it via the round hole in the firewall? I remember cleaning out that area during restoration; fortunately no where near as rusted as yours and I think I did it via that hole. Getting the heater out for me wasn't difficult as it was not a Smiths (and I never put it back).
Tom's knob.jpg    15.5 KB
vent5.jpg    17.9 KB
Gokart Avatar
Gokart Rob Illingworth
Where Tom's knob connects to, the upper green circle, is a problem as discussed. The knob then goes through the hole where the lower green circle is.
Whatever you do the upper air box needs to be drained through both holes. If not any water will collect where the black circle is.
I think this is a problem with perished & non free draining knobs or hoses. as the water leaking out from the hose goes into the lower supposedly sealed air box and if it fills enough it will overflow out the foot well vents and then stay in the bottom of the foot well until it eventually rots that out as well.
Cheers Rob
Gokart Avatar
Sorry I thought the photo had attached.
Cheers Rob
rheater.jpg    70.7 KB
L84DNR Luke Clement
This is an awesome pic! It looks like I should be able to access it if I pull the heater box. Or inside behind the radio console. Thank you!
