Dick The WIZARD. Problem got fixed just by his saying he'd help!
Nicecar Avatar
Nicecar Gary (ex "Harv") G
Victoria, BC, Canada   CAN
I needed someone to diagnose a sound. I sent an e-m to Dick asking if I could call, and he graciously replied "Anytime".
But Dick is a busy guy and a generous guy doing his own stuff and helping many. Which is more? So decided to do some investigating before I called him and wasted ANY of his time.
Car had been running beautifully. Only recently took advice from here: "Drive it Like you STOLE it", and it's a gas.
Last evening from a dead stop, I accelerated hard, harder than I ever have before. What I heard from engine was so troubling I turned car off at 5 way intersection red light. On green I moved it around corner & turned off again.
Knocking continued when running. I was less than a mile from home. Drove home, able to coast downhill (engine off) the last 3 blocks.
Oil pressure normal. Tiny oil stain normal after hours parked. I'm was afraid to drive it until I knew, so contacted Dick.
Here is what I found. First pic is carefully shot to show what I first saw. (or actually didn't see). Moving head around found culprit.
So now my only question: I just installed a Moss silicone gasket a few week ago (wonderful no weeping) but how to I re-attach? (Cover metal is now clean $ dry.) Last time I placed a thin bead of shown Permatex Sealant all around. Was surprised it didn't hold on cover removal. With what should I clean gasket, (Isopropyl?) and what sealant to re-apply? Prefer to use one from pic shown.
So before any of youse funny guys thinks of this and claims it, I'll say it first;
"A Nut off his Rocker"!
Also, here's Pic I sent Dick last night to give him a chuckle- never used it before 'cause it's out of focus.
Edited 3 time(s). Last edit at 2017-08-12 07:23 PM by Nicecar.
What I First Saw.JPG    53.7 KB
Nut off : CU copy.JPG    53.6 KB
My gasket sealants.JPG    57.4 KB
Better with Ketchup.JPG    26.7 KB
barry s Avatar
Alexandria, VA, USA   USA
1972 MG MGB GT
1976 Triumph TR6
So, you failed to tighten one of the nuts on a rocker adjustment screw and your question is how to reinstall the valve cover? If you previously installed the silicone gasket properly onto the valve cover, you would place the valve over the studs and tighten in place.
dipstick Avatar
dipstick Kenny Snyder
1941 Ford N-Series
1970 MG MGB GT "Pat's GT"
Gary, If you don't have one all ready purchase a Snap-on 1/2" 6-point box end combination end wrench for the rocker arm adjusting nuts. The 6-point wrench will fit the nuts precisely, not round off the corners, and last forever. Additionally, purchase a flat blade screwdriver that fits completely snug into the adjusting screw. The face of the adjusting nut can be flattened by hand pushing on a file. Given the circumstances I suggest inspecting the push rod involved.
Be safe out there.
Kenny
OSH16B Snap-on 6-Point.jpg    3.4 KB
Nicecar Avatar
Hey Barry:
So instead of just posting with intention of TRYING TO embarrass me now again for umpteenth time (will it ever end?), you only reflect poorly on yourself.
Why not be constructive and answer my question?
Nicecar Avatar
Oh Kenny:
See: Just want to find formula for to seal a soiled silicone gasket.
Alliteration on purpose. (But Thought of in 3-D!)
dipstick Avatar
1941 Ford N-Series
OK on the silicone gasket, I have never used one. But it appears that an enhanced valve adjustment technique might be in order.
In reply to # 3571797 by Nicecar Oh Kenny:
Be safe out there.
Kenny
Gary,
I appreciate the kind words, but all the credit is yours for being resourceful and finding the problem. Good for you... thumbs up
Can't help with the silicone gasket; I don't use 'em...
barry s Avatar
1972 MG MGB GT
1976 Triumph TR6
Gary/Harv - What's your problem? You asked what you needed do to reinstall valve cover with the silicone gasket that you installed (after much discussion) shortly ago. I told you. If the gasket was properly installed onto the valve cover there is no special procedure to reinstall it onto the head. This is also true of cork gaskets, properly installed onto the valve cover, if not over-tightened nor so old that the cork no longer has any resilience As to your botched valve lash adjustment., you should be seeking help/advice.
You're welcome.
HiPowerShooter Avatar
Set the valves using a slotted screwdriver and 1/2" wrench. Tighten the adjusters "snug", Install a new valve cover gasket (dry) and torque down just past finger tight. I don't understand what the issue is...
Nicecar Avatar
"an enhanced valve adjustment technique might be in order".
I've adjusted my valves many time without an issue.
My notes show I adjusted this 0.001 in April.
All others are tight.
A bit more diligence next time.
And I get to use my recently bought TOY (used only 2 occasions), vintage valve adj. tool!
Dick: I don't mean to put you on pedestal, but I have too much respect for the generosity of your time to all, that unless I'd just bought the beast and knew nothing, my 23 year ownership and 6 years here would make me lazy and foolish and a bit of a parasite not to do something so simple first.
So respect for your time gives you the "Assist".
Edited 1 time(s). Last edit at 2017-08-12 07:41 PM by Nicecar.
barry s Avatar
1972 MG MGB GT
1976 Triumph TR6
Such tools often are inferior to screwdriver, wrench and feeler gauge.
Rod H. Avatar
Amity, Oregon, USA   USA
1964 MG MGB
1968 MG MGB GT
Funny that Kenny should mention a Snap on six point purchased specifically for adjusting MG valves. I was just showing mine to a friend who recently became an MG owner. Also have a screwdriver that gets used almost exclusively for adjusting valves, and is close to Kenny's description, but no photo.
'63 MGB
'68 MGBGT
'80 VW Vanagon Kombi
20170812_174717.jpg    16.7 KB
benhutcherson Avatar
1970 MG MGB
Ashamed to say the same thing has happened to me...
At least you didn't have three...
BTW, the first time I set my valves I was a bit "soft" on the lock nuts for fear of stripping them or the screw. While I certainly don't put a ton of force on them, I at least now know that they need to be decently snug. I just use a standard Craftsman 1/2" combination wrench-without measuring I'd guess it's 7 or 8" long. Offhand, I'd guess I go finger tight and then about 3/8 or 1/2 of a turn past there.
Edited 1 time(s). Last edit at 2017-08-12 08:21 PM by benhutcherson.
Don't sweat the tools. You can do just as good a job using a crescent wrench, a cheap set of feelers and a butter knife if that's all you have so long as you know how to use them.
Seriously...this is a 2 on the difficulty scale. KISS...
I don't see anything critical of you Gary in the two first replies.
Grow a skin, please.
Yikeseye popping smiley
Not just on your finger
1978 MG MGB
