Pertronix Electronic Ignition Question
Chas69 Avatar
Chas69 Karl Mynyk
Orefield, PA., USA   USA
Could they be intermittent when failing (causing backfire) or do they just quit? Thanks. Chas
They just die
HiPowerShooter Avatar
Oshkosh, Wisconsin, USA   USA
That...One of the reasons some stay with points is that they will at least give you some warning rather than just go.
I've heard tell of a few who swear they had issues prior but most electronic modules of this sort either work or don't.
In reply to # 3568797 by ohlord They just die
Fresno, Ca, USA   USA
Gotts to disagree: When a fuse blows, or a light bulb burns out, it is "Done" After 20+ years working for the 3M Company as a Technician servicing their line of "Electronic" equipment. It could be "Intermittent" More tests are needed before "Chucking it "
Ex-Calif Avatar
Ex-Calif Gold Member Dan D
Cincinnati, Ohio, USA   USA
1977 MG MGB "Red Betty"
2012 Jeep Liberty "Tank"
2014 Hyundai Accent "Skate"
Solve for backfiring. Replacing the pertronix module is like troubleshooting step 10 or more...
What have you done so far?
Chas69 Avatar
Chas69 Karl Mynyk
Hi Dan,
The usual. Plugs, wires, coil. Also, New Weber.... trying to hone in idle mixture and timing by ear. Did not touch valve adjustments because it was not backfiring before I parked it 8 years ago. +Chas
They just fail...
In reply to # 3568816 by oleanderjoe Gotts to disagree: When a fuse blows, or a light bulb burns out, it is "Done" After 20+ years working for the 3M Company as a Technician servicing their line of "Electronic" equipment. It could be "Intermittent" More tests are needed before "Chucking it "
Ex-Calif Avatar
Oh. I see.
I stay out of Weber threads. No idea how to make them run right...
Good luck with it.
Look for vacuum leaks. Propane burner/rubber hose method (not lit)
Do First
Then
After the engine is sealed properly
Progress from ignition side over to carb side
Timing,plugs,valve lash,carb
Weber type? And supplier ?
ingoldsb Avatar
In the vast majority of cases, electronics do fail abruptly and terminally. However, it is possible to get a component that can "puncture" due to voltage or fail intermittently due to temperature.
I would be more inclined to suspect the rotor, cap or even plug wires than the Pertronix though.
Terry Ingoldsby
terry.ingoldsby@DCExperts.com
Fresno, Ca, USA   USA
MG and Triumph "Factory" Electronic Ignition, Intermittent as hell Customer complaint: "I was just driving along and it just quit, like you pulled the plug out of the wall. I pulled over, opened the hood and looked around. Could not find anything wrong. '(Pre Cell Phone Days, Remember when)" After about 10 minutes, i tried to start it back up. It started fine and I drove home. This is like the fifth time this has happened. Ring a Bell ????????
GMB3 Avatar
GMB3 George Badger
Soquel, CA, USA   USA
1968 MG MGB "1QUICK B"
Oh, the running great when parked syndrome.
Why the new carb?
If one thinks it is fuel related, it is normally electrical. And vice versa.
In reply to # 3568831 by Chas69 Hi Dan,
GEO
B-racer Avatar
B-racer Jeff Schlemmer
Shakopee, Minnesota, USA   USA
2014 Dodge Charger
I've seen issues with Pertronix where they misfire radically with certain sets of plug wires. I've also seen them start to fail, and timing will jump in increments. If your car has sat for 8 years, I'd look at the distributor itself as the mechanical advance assembly may be sticking or stuck. Lots of things can happen while parked for long periods, including corrosion inside the ground wires and battery cables. This is something critical to check and replace, especially in your climate.
jeff@advanceddistributors.com
kpeng Avatar
kpeng Ken Peng
Gainesville, Florida, USA   USA
1972 MG MGB "Trudy"
I have the Pertronix Ignitor setup, brand new Cobalt wires, HD rotor and new cap from Northwest Imports, and NGK plugs...car runs perfectly.
Y'all shouldn't be so afraid of modern electronics, this beats dealing with the points system any day.
1972 MGB
2014 BMW 335i
2008 Chevy Silverado 1500
2004 BMW 330i (Sold)
1988 BMW 325 (Sold)
I had an intermittent ignition problem that was caused by the green wire that goes to the seatbelt buzzer switch on the gearbox. The connector had popped off and every time it shorted to ground the tach dropped to zero and the ignition quit. It would blow the "green fuse" if it shorted badly enough.
Adrian
