Metal Flanges on under carriage, work very well for transporting my B!
danthefitman Avatar
danthefitman Dan H
Portland, Oregon, USA   USA
The metal Flanges on under carriage, work very well for transporting my B! Thanks to Dave Walsh, transporting my MGB went without incident!
Dave and I weren't sure, if the earlier model MGB have the same metal flange at front and rear underneath the carriage of the car? Do all MGB's have the same metal flange that is on the undercarriage for tying the car down with chains or just the later model MGB's from 77 to 80?
The metal flanges at the rear of the car passenger side and front of the car driver side, on the undercarriage, work really well for chaining the car down to a car transport trailer!
Thank you Dave Walsh!
dan@motorcardetailing.com or dan@fitnessintraining.com
the body is a temple, not a warehouse | for your body and your car
Edited 1 time(s). Last edit at 2017-07-17 04:04 PM by danthefitman.
IMAG1531.jpg    35.3 KB
BumbleB74 Avatar
BumbleB74 William Milholen
You mean the ones on the rubber bumpers?
danthefitman Avatar
danthefitman Dan H
Nope. They're not on the Polyurethane bumpers, they're on the frame of the car, well apart from the bumper. Yo.
29desoto Avatar
1953 MG TD
1977 MG MGB "Ole Yeller"
1979 MG MGB "Kermit"    & more
There's David, old Johnny on the spot. Did he bring doughnuts? grinning smiley
(he always brings the best doughnuts to ABFM, which is coming up soon. Oh, David........!)
Wayne Sanders
Rose Lodge, OR
(TD 4288)
77 MGB - Four tone paint -Pertronix - hood props - cheap tires - new springs all around - mixture of poly and rubber bushings- fuzzy seatcovers - stereo out of old F150 pickup -runs flawlessly and drives nice.
53 TD Mark II - a work in progress.
danthefitman Avatar
danthefitman Dan H
Morn'n Wayne, Dave is a rare breed, he actually helps people. He asks for little, gives much and has a fun way about him that puts people at ease. He's my friend and yours too. BRAVO David!
In reply to # 3554154 by 29desoto There's David, old Johnny on the spot. Did he bring doughnuts? grinning smiley
chris Avatar
Pendleton, OR, USA   USA
Yup!
so do you have pics of the flanges in question??
Used English car parts.
steve12955 Steve B
Massachusetts, USA   USA
1970 MG MGB "Emma"
My '70B has a tow bracket on each side of the front bumper under the overrider but none on the rear. When my car was towed due to a failed fuel pump the driver initially wanted to hook to them but decided instead to use the front crossmember. Once on the flatbed he tied down the rear using the leaf spring shackles on each side. He didn't use the differential since brake lines run along the axle tubes.
IMG_20170718_131245171.jpg    33.9 KB
danthefitman Avatar
danthefitman Dan H
Yo Chris, why yes I do! Please see attached images.
In reply to # 3554218 by chris Yup!
IMAG1541.jpg    25.1 KB
IMAG1540.jpg    26.6 KB
chris Avatar
Early cars didn't have those. If anything, it was like what Steve shows in his foto.
lewk Avatar
Cambridge, Ontario, Canada   CAN
My bet is those "flanges" have been added to the underside at some point. I don't think they are stock.
Edmonds, WA, USA   USA
In reply to # 3554448 by lewk My bet is those "flanges" have been added to the underside at some point. I don't think they are stock.
They are stock and were used for shipping.
rdgreen Avatar
rdgreen Robert Green
Adelaide, South Australia, Australia   AUS
In reply to # 3554252 by steve12955 My '70B has a tow bracket on each side of the front bumper under the overrider but none on the rear. When my car was towed due to a failed fuel pump the driver initially wanted to hook to them but decided instead to use the front crossmember. Once on the flatbed he tied down the rear using the leaf spring shackles on each side. He didn't use the differential since brake lines run along the axle tubes.
Steve, those brackets are for tying the vehicle down during transportation, not for towing. You might get away with it once or twice but I wouldn't make a habit of using them in a tow.
Rod H. Avatar
Amity, Oregon, USA   USA
1964 MG MGB
1968 MG MGB GT
Donuts? winking smiley Dave makes the best baked beans I've ever tasted!
'63 MGB
'68 MGBGT
'80 VW Vanagon Kombi
danthefitman Avatar
danthefitman Dan H
The brackets are definitely Factory. They were definitely not put on after market. Definitely!
Anybody know guys down here in southern Oregon that have MGB's and or British car shops that are reputable?
Edited 1 time(s). Last edit at 2017-07-18 06:31 PM by danthefitman.
mgbanthony Avatar
1962 MG MGB
1962 MG MGB
1970 MG MGB GT
1974 MG MGB    & more
I've spent some quality time in the towing industry....Those are designed and rated as initial shipping tie down brackets, and are absolutely not built to take the shock loading which happens with a car on a flat bed.
Front a-arms and either rear spring shackles or J-hooks on the rear axle tubes,placed so that the brake lines aren't crushed, which can be done by wiggling the J-hook between the brake line and the axle tube are the old safe standby towing points for MGBs.
Any rental trailer or commercial flat bed tow truck built in this century will be equipped with webbing harnesses for the 4 wheels...a damage free necessity for deck loading virtually any newish vehicle.
1972 MG Midget
