Jusdon Supercharged Sprite
OCDHerb Herb Goede
Colorado, USA   USA
Need some help converting to a weber carb. Can anyone help?
Herb
What's on it now? Just curious.
Adrian
OCDHerb Herb Goede
Colorado, USA   USA
Holley 1904.
riley1489 Gold Member Bruce H
Maybe talk with the AH Sprite forum members?
Check your ego Amigo!
Yep the Holley the Judsons came with are a pitiful little one barrel, non adjustable carb, I think I remember someone saying that they had used a SU on one before, and i sure that would require some sort of adapter. We did a hot rod 948 (I know those two things put in same sentence is a chuckle, hot rod 948 ) anyway it was built for a vintage Sherrock S/C and those use a single H6 carbs, here's a pic of it.
KGsc-5.jpg    53.1 KB
I came across this 'adapter' on eBay a while back.
It is no longer listed but may serve to inspire?
BH_shorrock.JPG    11.9 KB
ozieagle Avatar
1958 Wolseley 1500 "Wooly"
1966 MG MGB "Bl**dy B"
Sheesh...that supercharger is nearly as big as the engine!
Herb
Herb, you said a mouthful there, LOL, here's a view that show just how much real estate this charger takes up, but all fit under the bonnet of Bugeye Sprite. The car this engine is going is clone of a factory works rally aluminum bodied Mark 1 Sprite. They were actually two of these works cars, one blown, one normally aspirated, and my customer is cloning both cars, so we just finished the normally aspirated motor, it is 948 taken to FIA 1000cc rules. These cars were rebodied in the UK in aluminum, they have a more laid back windscreen rake than your normal Bugeye, and they have custom aluminum hard-top, and custom made side curtains. The final restorations are being done by Skunk River Restorations in Iowa, which is a awesome restoration shop. I feel very honored to be fortunate enough to work on such projects.
rbastedo Avatar
rbastedo Rick Bastedo
Snoqualmie, WA, USA   USA
Hap, you've got me wanting more...
Where's the pictures?
In reply to # 3554088 by Speedracer Herb, you said a mouthful there, LOL, here's a view that show just how much real estate this charger takes up, but all fit under the bonnet of Bugeye Sprite. The car this engine is going is clone of a factory works rally aluminum bodied Mark 1 Sprite. They were actually two of these works cars, one blown, one normally aspirated, and my customer is cloning both cars, so we just finished the normally aspirated motor, it is 948 taken to FIA 1000cc rules. These cars were rebodied in the UK in aluminum, they have a more laid back windscreen rake than your normal Bugeye, and they have custom aluminum hard-top, and custom made side curtains. The final restorations are being done by Skunk River Restorations in Iowa, which is a awesome restoration shop. I feel very honored to be fortunate enough to work on such projects.
