Steering column
MBuringrud Avatar
MBuringrud Mark Buringrud
Debary, FL, USA   USA
Good morning, I am trying to find upper steering column rebuild kit. I have read many previous posts on the subject. My "B" is 1972. I have sent a PM to Gerry Masterman a few days ago, so far I haven't heard back. Does anyone know if parts are available from anyone other than Gerry???
Gerry Avatar
Prairieville, LA, USA   USA
Mark, I have not received a PM from you. Gmasterman@aol.com works better than PMs
MBuringrud Avatar
Debary, FL, USA   USA
Sent an e-mail
Gerry Avatar
Email did not arrive, either.
In reply to # 3553114 by MBuringrud Sent an e-mail
MBuringrud Avatar
Debary, FL, USA   USA
Not sure what the email problem is. Maybe going to spam.... anyway, I am looking for upper steering column rebuild kit for a 72 "B".
Gerry Avatar
I apologize if the following looks like advertising but other methods of passing this info on to Mark have not been successful.
 Thanks for your interest in my products. At present time I have two products available.
MG-106 MGB steering column repair kit-top only. This kit replaces the poor quality original ball bearing and retainer with a custom made Derlin bushing. This kit can be installed without removing the column from the car in about an hour. This kit sells for $45 and include shipping within the mainland USA.
MG-107 MGB steering column repair kit top and bottom. This kit replaces both top and bottom bearings with Derlin bushings. The column must be removed from the car and disassembled for installation. The steering shaft must be split at the slip joint and then the slip joint repaired during the process of reassembly. Complete instruction on this process are included. This kit sells for $50 and also includes shipping within the mainland USA.
Both kits are designed to fit US spec collapsible columns in 1968 thru 1975 MGBs.
Should you be unable to install the kit yourself, I also offer a rebuilding service. In this service, your column is disassembled, de-rusted, MG-107 kit installed and slip-joint repaired. Column is then painted in hammertone black and shipped back to you within the mainland USA. Price for this service is $150.
Payment can be made either by personal check or by Paypal to Gmasterman@aol.com
Thank you for your interest.
Gerry Masterman
16195 Ole Homestead Lane
Prairieville, La 70769
If you have any questions please do not hesitate to contact me at Gmasterman@aol.com
In reply to # 3553342 by MBuringrud Not sure what the email problem is. Maybe going to spam.... anyway, I am looking for upper steering column rebuild kit for a 72 "B".
No need to apologise Gerry. Unless I'm mistaken this exactly the type of "commercial" answer that Skye allows. Not only are you answering Mark directly but you're telling the rest of us what service you offer if we want to avail ourselves. My only gripe is that you don't have a kit for my '79.
Gerry Avatar
Barrie, what column do you have? Is it a US spec collapsible column or is it like the Brit spec non collapsible? The reason that I do not offer a RB kit is because RB columns are a bit more complicated to install and will require a small amount of machine work. Generally speaking the RB columns have a better design top bearing that the earlier CB columns. The easiest way to tell what you have is to look at the turn signal switch. Does it use the metal clip on the steering shaft to reset the switch or is the reset cam made into the switch? Can your switch be removed WITHOUT removing the steering wheel? If it can be removed it is likely a CB style column. If the switch has to pass over the end of the shaft , hence requiring the steering wheel to come off, then it is a RB style column.
The one below Gerry. IDK if it even needs "servicing" but while it's out etc. I serviced my '66 column during the rebuild.
column.jpg    28.8 KB
MBuringrud Avatar
Debary, FL, USA   USA
Thanks Gerry! I sent another email as well as a paypal for the upper and lower set. I hope you receive them this time. Thanks again!!!
MBuringrud Avatar
Debary, FL, USA   USA
Gerry, I am not sure were the disconnect is at... can you confirm ine way or another?
davef Silver Member dave franchino
madison, WI, USA   USA
Howdy,
I just wanted to respond to this and move this thread back up top for a minute and put in a plug for Gerry and his steering column rebuild kit.
I just finished installing his kit in my B. The parts were well manufactured, the instructions were clear and easy to follow, Gerry responded immediately to a quick question I had and most importantly the kit functioned perfectly in terms of renewing what had been a very sloppy steering column. It's a brilliant design - far better than the original. His fix for the collapsing column was another bonus.
Great service and I'd highly recommend it.
Dave
Ex-Calif Avatar
Ex-Calif Gold Member Dan D
Cincinnati, OH, USA   USA
1977 MG MGB "Red Betty"
2012 Jeep Liberty "Tank"
2014 Hyundai Accent "Skate"
I'll second that. I just did mine a couple weeks ago. Gerry did an "emergency" shipment as I was off on a road trip the following Friday and I am sure Gerry got the package off within a couple hours.
Super job and the kit worked great.
