What are these hoses?
blista1989 Alistair S
Bristol, Bristol, UK   GBR
1972 MG MGB GT "Blue Steel"
Today I will be replacing all of my radiator cooling hoses and the breather hoses. In the very near future I'll aim to do the fuel and brake hoses as well.
Also on the list for today is fitting wheel arch protection (currently it doesn't even have baffle plates), replacing the washer motor and giving it a damn good clean.
Thanks again for the advice.
Alistair
theycallhimart Avatar
theycallhimart Arthur Taylor
Victoria, BC, Canada   CAN
HS Carbs with crankcase breathers did exists. I've seen them with my own eyes on a 71 or 72 B. Of course, this being Canada, not sure if that combo did exist in the states bound Bs.
"All mine go through a PCV valve on the manifold. Are these from a specific year or a UK item?"
An alternative to #20 which goes from separator to PCV. I assumed they were on whichever year(s) NA cars too as they've been discussed in the past but I didn't search.
hose1.jpg    9.2 KB
oshawaMGguy Avatar
oshawaMGguy Greg Wright
Oshawa, ON, Canada   CAN
Ditto on replacing fuel line hoses, if not all hoses as a precautionary measure. I just had to replace the needles and seats in my HIF4 carbs as gas was leaking through the carbs and not getting to the engine. I still had problems after replacing them. At the suggestion of others here in the forums I replaced the fuel line hoses (they can break down and send bits of rubber to the carburetors.) After replacing them all seems good.
1974 1/2 Blaze Red MGB, member of the British Saloon Car Club of Canada (EastEnders Chapter)
Success! Replaced the breather hoses! Took all of 3 minutes in the end. I also managed to replace the top and bottom coolant hoses, replace the broken washer motor and start fitting the wheel arch proection. The worst part was definitely jacking the car, it always makes me nervous.
Thanks again all for the help. Also Bristol Moss has a physical shop with some very knowledgeable staff who helped to make sure I picked up the correct parts.
Cheers
Alistair
20170716_191948.jpg    65.3 KB
Noble66 Avatar
Orlando, FL, USA   USA
1964 MG MGB "Black Betty"
1969 MG MGC GT
1974 MG MGB "Whitey"
Looking closely at this picture I noticed the carbs are HS6s not HS4s. The float bowls are at an incorrect angle and the spacers look to be aluminum.
Definitely not a stock set up.
The engine is bored out to 1950cc. Would the change in carbs be part of this mod?
riley1489 Gold Member Bruce H
In reply to # 3553479 by Noble66 Looking closely at this picture I noticed the carbs are HS6s not HS4s. The float bowls are at an incorrect angle
Noble,
You know there is so many susceptible owners on this site I chose to not mention this earlier on. winking smiley
Yes these are HS6 carburetors. Fortunately all SU HS float chambers are the same, and fitted to 2, 4 & 6 size carburetors.
The owner can source float chamber adapters from Burlen to make these sit at the correct orientation/angle. A straight forward thing to do. With the OP being in the UK this is a simple phone call away. cool smiley
We cannot see the rear carburetor float chamber but it may be right?
Check your ego Amigo!
Bruce and Noble,
I appreciate the input. I've only had the car a couple of months and it came with virtually no history so whatever an experienced eye can divulge is incredibly useful.
What's the downside to having the floats at the wrong angle?
Thanks
Alistair
Noble66 Avatar
1969 MG MGC GT
In reply to # 3553486 by blista1989 The engine is bored out to 1950cc. Would the change in carbs be part of this mod?
Likely that was the idea. You'll get argument over whether it's a good idea. You still need to get the proper spacers to level the float bowls. There's a little spacer that goes between the float bowl and the carb body that changes the angle. Switching them from one carb to the other might do the trick for a quick fix. The proper ones are for sale from various vendors.
In reply to # 3553499 by blista1989 What's the downside to having the floats at the wrong angle?
The fuel in the float chamber is like any other liquid and ultimately should sit level in its container. The fuel being level will make the float/fuel shut off valve function efficiently. Think toilet tank or the like. winking smiley
Noble66 Avatar
1969 MG MGC GT
Bruce,
In my experience I have found the bowls are the same but the lids vary depending on application. The inlet and outlet pipes are pointing in different directions on my HS6s (MGC) than on my HS4s MGB). The lids still fit but the hoses have to be rerouted.
Alistair,
Fuel starvation is the main reason for leveling your float bowls. But there's also leaking lids and more chance of overflow.
MGBUK Avatar
MGBUK David C
Chesham, Bucks, UK   GBR
1980 MG MGB GT "JAM"
Hi Alistair,
you can actually run those breather pipes off to an oil catch tank if you want? all the pipes are doing is sending crankcase oil vapour to the carbs to be burnt off, you can catch it instead, who knows longevity of plugs / innards or maybe even re-use the oil if you catch a lot of it smiling smiley
i fitted a catch tank in the corner on the inner wing by the rad and loop the breather hose to the catch tank and then to the carbs.
hth
In reply to # 3553561 by Noble66 Bruce,
Noble,
One never knows what level of detail to provide in a given thread, confusion will take place. For example this thread pertains to hoses .................... grinning smiley
Yes I am fully aware that these lids differ for HS models. I have worked on many SU types, and have met many differences with these HS types. The lids are numerous (below) as is the chamber adapter (below).
As I stated earlier, the OP should not have any issue sorting his float chamber mounting angle.
info source courtesy of SU reference catalogue 7th edition
Edited 1 time(s). Last edit at 2017-07-17 10:59 AM by riley1489.
BH_HS lids.JPG    74.6 KB
BH_chamber adapt.JPG    81 KB
In reply to # 3553572 by MGBUK Hi Alistair,
The MGB engine design has been sending crankcase gases to the intake since 1963.
There is a built in "oil catch tank " in the front tappet gallery cover. No worries about blow by affecting "longevity of plugs / innards " .
