Mystery wire
Rex.keene Rex Keene
Tårnby, Sjælland, Denmark   DNK
Can anyone tell me where this white with black trace wire goes to? I don't seem to be able to find it on the autowire diagrams.
The only things I can think of in this area of the engine bay are the coil or distributor, possibly the alternator but the wire is much too short for that.
The car is a LHD '70 GT.
IMG_0540.JPG    58.1 KB
RAY 67 TOURER Avatar
RAY 67 TOURER Ray Marloff
Fort Bragg, CA, USA   USA
1967 MG MGB "My Girl"
That would have been the color of the stock wire going from the coil to the distributor points. Being cut and reconnected, it's difficult to tell. RAY
Rex.keene Rex Keene
Just realised the photo is a bit ambiguous: The wire going left to the coil is plain white.
The mystery white with black trace emerges from the loom at the same point.
The photo may look as if I'm asking about the wire attached to the coil but in reality the photo is showing two separate wires, the white running left and attached to the coil, and a white with black trace emerging from the same place on the loom, pointing off to the right and ending with a space connector.
riley1489 Gold Member Bruce Hopgood
Rex
Ray is spot on.
The White/Black trace wire from negative side of coil to distributor
Check your ego Amigo!
If that wire is actually white with a brown tracer then it was likely for the electrical oil pressure sending unit as was used for just a couple of years...
I thought we were discussing WB wire?
another colour blind chap perhaps? grinning smiley
Time can play tricks with wiring colors...
In reply to # 3535796 by riley1489 I thought we were discussing WB wire?
Rex.keene Rex Keene
Ah, thanks for that, I hadn't thought of the oil pressure sender, and I do have an electric gauge.
I'll have to double check it, but I'm sure it was black, not brown, but I've been wrong before!
BumbleB74 Avatar
BumbleB74 William Milholen
Also the white/black runner goes to the tach?
ClayJ Avatar
Mt. Olive, MS, USA   USA
William,
The tach sense is either white (using a current sensing tach) or white-black (if using a voltage sensing tach). A 70 should be white wires at the tach that in-turn power the <pos> side of the coil.
As noted above, white-black is always trigger from dizzy.
