Emission system hoses 1970 MGB
  This topic is about my 1970 MG MGB MkIII
Gary O Gary Ohrstrom
Rock Island, IL, USA   USA
I need some help on where I can purchase the hoses for the emission system. I'm just starting to clean up a 1970 B that has 18K original miles but has not been run since fall of 1974 and have found that all the rubber hoses are rotted, emissions, fuel, brake, vacuum and cooling. Most of these are readily available but haven't found the emission hoses anywhere? I've read the post Awakening a Sleeping MG (great info).
1970_1.jpg    36.8 KB
1970_3.jpg    51.8 KB
PTorto Avatar
PTorto Pete Tortorici
Bartlett, IL, USA   USA
1974 MG MGB "None"
Nice find.......I think any auto parts store will have the hoses you'll need..........love the split bumpers.
RAY 67 TOURER Avatar
RAY 67 TOURER Ray Marloff
Fort Bragg, CA, USA   USA
1967 MG MGB "My Girl"
You should be able to find what you need at Moss Motors or Victoria British. RAY
Thanks, but I've tried all the usual sources, Moss, British Victoria, Roadster Factory and a few others and no luck. The straight lines won't be an issue its the molded one's that's the problem...
Do you really need them to pass emissions or just to return the car to stock appearance? RAY
Just want to keep it original let the next owner decide if they want to de-smog it.
Tucson, AZ, USA   USA
1967 MG MGB
1967 MG MGB GT
1971 MG MGB GT
Can you give a part number from the Moss catalog for the ones you need?
I'll pull the book out tonight and post them.
After taking all the emission pieces of this evening I see that there are only two hoses that are molded those are the below -
367-215 hose, pump to check valve
367-220 hose, gulp valve to air pump.
