rear upper bump stop surgery
glbishop Avatar
glbishop Gary Bishop
Spring Hill, FL, USA   USA
Gas tank dropped for replacement so I've decided to remove the rear bump stops to better match my re-arched springs.
Shortened rubber bumpers alone don't allow full upward travel so I want to "roll back" the design.
I know this has been written up by Lloyd and others, but before I start can someone tell me where they made their first cut. The extension hangs down from the body and I am planning on cutting along the original body line directly above the extensions. follow the original contour. Then I plan on bending it down to expose the inner side of the extension where I'll do the same.
I may drill a series of small holes along the cut path first.
Edited 1 time(s). Last edit at 2017-06-18 08:50 AM by glbishop.
WP_000715.jpg    39.8 KB
WP_000716.jpg    47.7 KB
WP_000714.jpg    34.7 KB
rocannon Avatar
Inconveniently located in the wilderness, Oklahoma, USA   USA
1967 MG MGB GT "GT From Hell"
Lloyd mentions using an air chisel.
TANSTAAFL !
riley1489 Gold Member Bruce Hopgood
Gary,
Here is a link to the thread that describes the lowering process.
http://www.mgexp.com/phorum/read.php?1,1329892
may be worth a read to refresh your memory?
Be careful
Check your ego Amigo!
Edited 1 time(s). Last edit at 2017-06-18 02:04 PM by riley1489.
glbishop Avatar
In reply to # 3534767 by riley1489 Gary,
may be worth a red to refresh your memory?
Be careful
Thanks for that link.
I looked at the magic before and after and was hoping for some guidance for the plan of attack.
As Lloyd warns, don't want to screw up the body rails.
I started working on one side. After it's fully removed I'll have a better idea on how to remove the other in the least amount of time with no damage. Won't be today.
I was hoping for
rocannon Avatar
Drop Lloyd a PM.
TANSTAAFL !
glbishop Avatar
I ended up drilling pilot holes along the parting line and used an air chisel to make a clean cut.
I did the outside and bottom first then cut and bent down the section to gain access to the inner wall.
Again I drilled pilot holes then cut with the chisel.
The upper wall of the section is spot welded to the frame rail so I left it in place.
The bump stop nub will get welded directly to it.
There was a single weld holding the section to the strap hanger bracket.
Here are a couple pics.
WP_000721.jpg    35.2 KB
WP_000722.jpg    40.1 KB
WP_000723.jpg    41.9 KB
WP_000724.jpg    42.2 KB
glbishop Avatar
More pics
Edited 1 time(s). Last edit at 2017-06-20 12:59 PM by glbishop.
WP_000725.jpg    46.2 KB
WP_000729.jpg    39.7 KB
V8MGBV8 Avatar
V8MGBV8 Carl Floyd
Kinggsport, TN, USA   USA
I was considering using a cutoff wheel.
glbishop Avatar
In reply to # 3535812 by V8MGBV8 I was considering using a cutoff wheel.
I have a 3" cut-off air driven and I used it a tiny bit.
Tight space and too many curves.
If the entire rear end with springs was dropped there would be more opportunity to use the cut-off and grinder.
With a new sharp drill bit the holes drilled very quickly and the air chisel makes quick work of cutting.
Ear plugs no matter what you use.
glbishop Avatar
Raising bump stops is well worth the effort for a significantly lowered rear end.
It was more difficult than expected with all running gear in place. The gas tank was dropped for replacement and I removed the lever shocks too. Work space was tight but the job can be completed with the rear end in place.
I also flushed and refilled the lever shocks. One thing to note... my shock control valves did not have ANY shim washers under the large spring. I reassembled them as they were. Refilled with ISO46 hydraulic fluid and dampening was improved. Now the front shocks need to be flushed and filled too.
Back on the road today and not a single occurrence of bottoming on the rear bump stops.
Before surgery I would need to be a bit careful about hitting bumps at speed.
Test road has a long straight (1.5mi) followed by a long sweeping 90 deg turn. 90mph on the strait and dropped to 75 on the corner just in case a surprise was waiting. The road at times is well traveled and many keep to the speed limit. But today, the newish Mustang that followed, had me stepping it up. The Mustang dropped back half way along the straight and then made quick work of catching up. I was going 90 ... he must have been doing 130 to catch back up. Several more curves on this road and every one has a warning light showing the 35mph speed limit. It begins to flash if you're over the limit so needless to say they all were flashing.
One 'S' turn with a rise at the waist that crosses a set of RR tracks. That was a perfect test of the rear suspension. No problem flying over the tracks. Low 90's today in FL. No RAIN and only a few clouds. Today was the first day WITHOUT rain in about a month. Felt good to be back out on the road.
1949 MG Y Type Saloon
