Thermostat sensor wire jacket in which houses two wires
gary1977 Avatar
gary1977 Gary F
Media, PA, USA   USA
1977 MGB
Thermostat sensor wire jacket in which houses "two wires" one connected to the sensor on the engine
block ........ However
Where does the other one go? (it's a much shorter in length) the color is green/blue.
Thank you in advance. smiling smiley
Possible that the shorter wire goes to the temperature gauge sending unit and the longer wire runs across the engine to the induction heater for the ZS carb (if still so equipped...)?...
In reply to # 3514651 by gary1977 1977 MGB
ClayJ Avatar
Mt. Olive, MS, USA   USA
As Dick notes, I've attached the Late US Spec wiring for each device.
Capture1.jpg    4.2 KB
Capture2.jpg    2.6 KB
Thanks, Clay.... thumbs up
riley1489 Gold Member Bruce H
Pay attention to Clay post
The Green/blue, (GU) wire is for the temperature sensor/sender at the cylinder head below the thermostat housing.
Your post reads as if you have the green wire, (G) connected to the sensor/sender, and incorrect? confused smiley
Check your ego Amigo!
Edited 1 time(s). Last edit at 2017-05-19 12:00 PM by riley1489.
gary1977 Avatar
gary1977 Gary F
Media, PA, USA   USA
Here is a picture where do I plug that into?
As stated before these two wires are in the same jacket.
Thank you.
P5190001.JPG    54.9 KB
I believe the green wire has been shortened, as IIRC that black rectangular connector is not OE. I suspect that wire was originally longer to reach across to the induction heater on the original ZS carburetor. Perhaps the induction heater has been removed or disabled, or perhaps the ZS carb has been replaced with one of a different configuration...
In reply to # 3514737 by gary1977 Here is a picture where do I plug that into?
Thank you.
