1978 MGB changing reverse/backup switch
j949186m Gold Member Ian Crozier
Buckhannon, WV, USA   USA
Has anyone changed the reverse/back up switch and how difficult is it. Thanks. .......Ian
Quite easy. It's on the top right side of the gearbox. Just pull off the two spade connectors and unscrew the switch. Access is a little awkward but not too bad.
The switch is adjusted by adding or removing (usually red...) fiber washers from under the switch. Probably using one washer will work for you.
During reassembly, it doesn't matter which wire goes on which connector on the switch, since all the switch does is complete the connection between the two terminals...
BumbleB74 Avatar
BumbleB74 William Milholen
Do you have a continuity tester? I would be tempted to verify the switch is really bad, versus the wiring to and from it. Many times that segment of wiring gets pretty beat up for various reasons.
On my '76.....it looked like it had been drug down the road for many miles...just an awful mess.
Thank you Dick and William. Tested the circuit and all was okay apart from a badly frayed wire. All working again.
Regards....Ian
thumbs up
In reply to # 3514898 by j949186m Thank you Dick and William. Tested the circuit and all was okay apart from a badly frayed wire. All working again.
Regards....Ian
