2nd fuse up from bottom very hot to the touch
benhutcherson Avatar
1970 MG MGB
In reply to # 3514122 by ingoldsb If there is a short (or a device drawing excessive current) it should blow the fuse (unless someone replaced the fuse with one of much larger value).
There's such a thing as a high resistance short that can cause high currents but not necessarily enough to blow the fuse right away.
Something like chafed insulation against a rusty body panel could cause such a situation.
perfectpitch Avatar
Edited 1 time(s). Last edit at 2017-05-19 02:47 PM by Skye.
rocannon Avatar
1967 MG MGB GT "GT From Hell"
This is one of those "why didn't I think of that?" type posts. Thanks.thumbs up
In reply to # 3514233 by oleanderjoe A lot of MGB Wiring issues can be traced back to the FUSE BLOCK> There was a Post on this site last week about "STAKING" the connections with a punch. I do that and also BRIDGE SOLDER the connections on the back side. A LOT of intermitant electrical issues disapear after that. Have Fun
TANSTAAFL !
rocannon Avatar
Tap tap tap
He's back... sleepy
In reply to # 3514480 by perfectpitch More endless drivel from the morons at mgexp. Rob ate some elk skit today and was hoping for something differnt fur desert. Who cares? Nobody. XXmyA
TANSTAAFL !
bleteaches6 Avatar
Bonney Lake, WA, USA   USA
Well Charles aka perfect pitch
The term is Elk skat, not skit and we don't need your level of posting on the experience. Clean it up or leave.
Nicecar Avatar
Nicecar Gary (ex "Harv") G
Victoria, BC, Canada   CAN
At the risk of being called a moron (again), with my drivel useless comment, Gary, if within one week of solving, you can edit your thread title and add "Solved", (1 week time limit), but please inform us what you found.
