Machine shop in NH or MA for cylinder head work?
MGB 1976 Avatar
MGB 1976 Silver Member Mark Turechek
North of Boston, MA, USA   USA
1976 MG MGB "The Never Ending Project"
Can anyone recommend a machine shop that can perform MGB cylinder head work (porting) in New Hampshire or Massachusetts?
MGB 1976 Avatar
Has anyone had any work done by Autoshop Machine Services?
http://www.autoshopmachineservices.com/
Mark,
Beyond porting, what is your plan for your engine?
MGB 1976 Avatar
I've had hardened valve seats and larger valves installed in my 12H-4736. I haven't assembled the head yet. I didn't have it ported because my budget kept me from completing it last year. I have an 18V, had the crank magnafluxed, balanced and polished, 030 over shallow dish pistons, balanced con rods, VP12 cam & new bearings installed. Currently unassembled bottom end. Plan to install a cast iron stock exhaust manifold with dual SUs, have a points 25D set up by Jeff. Do I need dual springs for my head, or are the stock single springs OK?
dmarth Avatar
dmarth Silver Member Dennis Marth
Aiken, SC, USA   USA
1963 MG MGB "Thunder Bolt Grease Slapper!!"
1993 Cadillac Allante
1998 BMW MC R1200C "Klaus"
Mark,
Not exactly up the street from you, but Advanced Engine Rebuilding in Wareham, MA are excellent. They do great work and will work with you to whatever spec you require. The gentleman who owns the shop is named Hans, nice folks. They built my engine for me several years ago.
Give them a call (508) 295-2288.
Dennis
Phantomracer Avatar
Phantomracer Paul Seeberg
Boston, MA, USA   USA
1972 MG MGB GT "72 White GT"
1980 MG MGB "Phantomracer"
Precision engine in Dighton does a great job. did 2 engines / heads for me including P+P etc
http://seeberg.com/piwigo/index.php?/category/248
An MG is never 'finished', if there is nothing for you to currently work on it is merely 'resting'.
New My 1980 MGB roadster 'refresh' facebook page (please 'like' to get updates)
My Facebook page
1980 MGB Inca Yellow
1972 MGB-GT Glacier White
My (needs to be updated) lousy website
Brittanic Motors-Premier British Car Service
mikedwolf Mike P
Sanford, Florida, USA   USA
A friend of mine used to work at R & L Engines in Dover, NH. I have no experience with them, but he had good things to say.
steve12955 Steve B
Massachusetts, USA   USA
1970 MG MGB "Emma"
ABT Machine, 1649 Washington St., Holliston MA. 508-429-4355. Recommended by area MG specialists. Rebuilt my head a few years ago (hardened seats, guides, valves, springs) and repaired crack between cylinders 2-3. They also prepare race engines.
MGB 1976 Avatar
Actually, I think I just need the valve seats blended into the bowl.
In reply to # 3517280 by MGB 1976 Actually, I think I just need the valve seats blended into the bowl.
They can do that with bowl cutter on the valve & guide machine, if that is all you need done.
