Engine Rotation?
perfectpitch Avatar
CW or CCW, that is why the Lucas distributor should have a little arrow pointing to the left or to the right. If you install a CW Lucas distributor in a CCW engine, the scroll seal oilers will reject the oil back down and soon your dist will burn up its bushings from lack of oil; also, the mechanical advance mechanism will not advance anything. Find a Lucas distributor catalog and you can hunt for British cars with "backwards" distributor rotation which will equal opposite engine rotation (from normal) as the catalog will list distributor rotation direction for each one. The MG XPAG engine (and distributor) runs "backwards".
Surewood Chuck S
Wallingford, CT, USA   USA
I thought the direction of rotation depended upon which side of the equator you reside on.
They do have an arrow......
In reply to # 3513096 by perfectpitch CW or CCW, that is why the Lucas distributor should have a little arrow pointing to the left or to the right. If you install a CW Lucas distributor in a CCW engine, the scroll seal oilers will reject the oil back down and soon your dist will burn up its bushings from lack of oil; also, the mechanical advance mechanism will not advance anything. Find a Lucas distributor catalog and you can hunt for British cars with "backwards" distributor rotation which will equal opposite engine rotation (from normal) as the catalog will list distributor rotation direction for each one. The MG XPAG engine (and distributor) runs "backwards".
malski Avatar
malski Silver Member Peter Malkin
Charles
I'm unsure as to your statement that the XPAG engine runs "backwards". The direction of rotation is indeed clockwise as is the B Series.
Peter Malkin
NE Victoria
Australia
MGBGTV8 (1977)
MGTC (1949)
GlennMGB Avatar
GlennMGB Glenn G
Fort Worth, TX, USA   USA
1967 MG MGB GT "Rose"
Quote: which way does the harmonic balancer rotate
Mine is quite still. But I and the rest of the universe spin around it in a counter-clockwise direction. It is dizzying at times.
albeegreen1 Avatar
bordentown, NJ, USA   USA
1972 MG MGB MkIII "ALBERT"
How bout Down Under? grinning smiley
eye popping smiley eye popping smiley eye popping smiley
In reply to # 3514699 by albeegreen1 How bout Down Under? grinning smiley
perfectpitch Avatar
I am very disappointed none of the experts here figured the rest of the simple equation. It is more than CW or CCW for the dist, you also must know which side of the engine the dist is on to figure engine rotation. I guess sometimes the most simple of things slip past the great experts here.
Tap tap tap
In reply to # 3514755 by perfectpitch I am very disappointed none of the experts here figured the rest of the simple equation. It is more than CW or CCW for the dist, you also must know which side of the engine the dist is on to figure engine rotation. I guess sometimes the most simple of things slip past the great experts here.
Triumphant66 Avatar
Triumphant66 Silver Member Kent C
Richmond, VA, USA   USA
1956 Austin-Healey 100M "ParisieM"
1963 MG MGB
1964 MG MGB "Nanette"
1966 Austin-Healey 3000 BJ8    & more
...or down under.
My first LBC: 1969 MGB purchased in July 1977 and been infected ever since...
