Question on which to use:knock-off adapters and use "modern" wire wheels or OEM
Verthosand Avatar
Verthosand Guy & Shelley L
Portland, ME, USA   USA
1973 MG MGB "Queen "B"
Looking for the advise of the wonderful MGB wizards...
I would be interested to know whether I should go with knock-off adapters and use "modern" wire wheels (since vintage ones are bound to need fixing/servicing/replacing) or go OEM from nearly 45+ years ago?
Thank you ahead a time for your replies.
Steve S Avatar
Depends on the condition of the wheels. If they are straight, well balanced and have good splines then original wheels are fine. If not then it's best to go with new ones, as a wobbly old wire wheel is never going to run as smooth as a straight one.
Flint Avatar
Flint Richard Conroy
Tucson, Arizona, USA   USA
1971 MG MGB "Maggie"
1978 MG MGB MkIV
Seems I recall that the modern new production wire wheels do not need tubes, as the old ones do, an advantage. You may also find new wire wheels with a wider rim for wider tires...
Redhawk1689 Avatar
Salina, Kansas, USA   USA
1958 MG MGA 1500 "Belle"
If you go with new wires, you will, in all probability, need to change out the splines as worn splines will quickly destroy new wheels. That being said, unless you are going for a numbers matching, concours level restoration where you are anal about using everthing original, go with new wires and new splines! I recommend the 60-spoke chromes as they are now tubeless and look sweet!
Bankerdanny Avatar
Bankerdanny Daniel Palmer
Chicagoland, USA   USA
1972 MG MGB GT "Dudley"
1975 Honda MC CB550F
If you are converting to wires go bolt on.
Endeavor to Persevere
"The problem with quotes on the Internet is that you never know if they're true" - Abraham Lincoln
Can't agree with you Daniel - the B (and other LBCs) deserves centrelocks.
OP what do you mean by your topic title? Are you asking do I replace my wire wheels with Dunlops using the oem Rudge style hubs or do I use the Dayton method of attachment or do you mean something else?
2150john Avatar
2150john Silver Member John L
Nolensville, Tennessee, USA   USA
I am not sure I understand your question but... New OEM style hubs and improved OEM style wire wheels are available. I just put 5.5 inch wide 15 inch chrome wire wheels and new hubs on my '74. With P4 Pirellis the ride is amazing. The wheels and tires were set up by Hendrix for a friends Healey. They are superb. (he decided to do another complete restoration on his Healey so I became the benefactor)
I would stay with the center locks with new hubs and wheels.
Bankerdanny Avatar
I love the look of my wires Barrie, but the cost of replacing them and the hubs is punishingly expensive. For the cost of 4 new 14" wheels and hubs I could easily switch over to 15" alloys PLUS a set of tires.
If he has bolt ons now and wants wires, I would recommend bolt on, partially because of the need to replace the rear axle if he wants to convert to factory style knock off wires.
If he is asking about what to do about existing knock off wires that need replacing, then the math is different. But you could still swap out to used bolt up hubs and add a set of bolt on Daytons for a fair amount less than all new knock off hubs and wheels.
Daniel if you already had bolt-on hubs then yes bolt-on wires makes economic sense. I assumed OP was referring to centrelocks but he hasn't responded so who knows.
Bankerdanny Avatar
Now that I re-read his question and look at the title, I think he is just asking what brand of replacement knock-off wires to use to replace his older wheels.
Verthosand Avatar
Sorry, for the delay in getting back to everyone's questions and answers to my post. Our son was getting married so our time was put into getting the wedding prepared. Now that that is all completed, we can get back to working on our project.
My wife's baby "Queen B" (the car's name, not the wife!) is very emotionally important to her, bringing her back to a time of youth, innocence, and freedom long lost (she is a Veteran of two wars). Her original car (1972) had wire wheels/knock-off spinners and OD trannie - which we could not find/afford in the Northeast USA. So we took a project car 1973 MGB with bolt-on steel wheels, tube rear axle and 4-speed trannie. Numbers are not important to us, emotional memories and appearance are. We have found a 4-Speed/OD trannie and will attack the engine restoration shortly.
After reading that the rear tube axle would have to be changed for knock-offs/wire wheels because of the different width/clearance problems, this is what we are wondering about after considering the age/wear/rarity of original components from that era (in our part of the world):
1- "Spinner/wire wheel conversion Improved Question":
Could we use our current tube axles/front spindles, add modern bolt-on knock-off spinner adapters (from Dayton for example), and fit 15x5" or 15x6" (preferred) wire wheels?
Has any enthusiast done the conversion?
If this is not possible, what would you experts recommend?
2- We are looking for an Air Pump/slider-adjuster, air pump filter, air injector tubes, anti-backfire valves system, if any one has one around.
3- We are also looking for the switch/control/wires to actuate the OD unit. We have the OD but the wires controlling it are missing (were cut off).
Thank you so much for your help, support and advice, Ciao from Maine, USA,
Guy & Shelley
albeegreen1 Avatar
bordentown, nj, USA   USA
1972 MG MGB MkIII "ALBERT"
Adapters can lead to clearance problems down the road with wider tires. Get the splined hubs and knock off wire wheels. Sleep tight.
LENZ Avatar
LENZ Jim Barlow
Leominster, Massachusetts, USA   USA
1974 MG MGB GT "Murphy"
cut off where? on the tranny or the stalk?
jim
tvrgeek Silver Member Scott S
Bowie, Maryland, USA   USA
I would convert to the correct spline axle and hubs, then spring for a new set of Dayton wheels. Round, tubeless, safe.
arnolda Arnold Adams
Vancouver, Washington, USA   USA
A good source for the wiring is British Wiring
http://www.britishwiring.com/MGB-s/16.htm
Arnold
