Front suspension grease nipples
  This topic is about my 1979 MG MGB GT
rapatterson Avatar
rapatterson Richard Patterson
High Wycombe, Bucks, UK   GBR
Just greased nipples on front suspension however only did 5 as the near side middle one was missing it looks to have been sheared off and showing no indication of where it was however it would be easy enough to take measurements from the off side unit.
Should I just forget about it or try to fit new one and how should I go about that.
Would like some advice as I guess this has happened before and is this a MOT failure?
Thanks
Richard
chris Avatar
Pendleton, OR, USA   USA
Find the location and then use an EZ Out to extract the remnants.
Used English car parts.
barry s Avatar
Alexandria, VA, USA   USA
1972 MG MGB GT
1976 Triumph TR6
You should worry less about MOT and more about a dry seized steering.
rapatterson Avatar
Chris
What is A EZ out?
chris Avatar
An EZ out is an extraction device. Usually, you have to drill a hole in a snapped off bolt, then turn the EZ Out into the remaining bolt shaft. The threads on the EZ Out are reversed from those of the bolt/screw/etc so as you turn it pulls the remains out of the threaded hole thatthey are in. In the case of a grease zerk, there is already a hole so no drilling needed. This has worked for me in the past.
Chalky Avatar
Chalky David White
chris Avatar
LOL! David, your explanation is so much quicker and succinct than mine! thumbs up
rapatterson Avatar
Barry
Sorry I am new to car maintenance after 50 years how will this cause my steering to seize?
bleteaches6 Avatar
bleteaches6 Lee Orphan
Bonney Lake, Washington, USA   USA
Barry
With out the grease, the component will "dry out" and eventually weld itself together with rust and corrosion. The grease keeps the components happy! smiling smiley
ozieagle Avatar
1958 Wolseley 1500 "Wooly"
1966 MG MGB "Bl**dy B"
I vaguely remember reading about a mod to early units, that originally only had two grease nipples. The mod was to fit a third one.
Maybe a PO had installed an old unit sometime, and there really isn't a third nipple.
Herb
barry s Avatar
1972 MG MGB GT
1976 Triumph TR6
Herb - This is a '79
ozieagle Avatar
Barry, I realise that, which is why I said maybe an older unit had been fitted, in the past.
Herb
TinyTin Avatar
TinyTin David Rogers
Merrimack, New Hampshire, USA   USA
1963 MG MGB "TinyTin"
My 63 has two fittings on the driver's side and three on the passenger side. The side with two fittings has no indication that a fitting ever existed in the same place where it is on the passenger side. I am assuming one side was replaced over the years as I doubt it came that way from the factory.
the omega man Avatar
the omega man phil wilkins
I've had one missing from mine for years, as long as top and bottom nipples are well greased, there should be no problem. The MOT man looks for play in the joint, they are not concerned about missing nipples.
rapatterson Avatar
Hi David
Yes I have the same situation but on the nearside after giving the area where the nipple should be a good clean there is no evidence of a nipple being there.
When they changed to six grease points were they the middle ones that they added?
Thanks
Richard
