two annoances
Tim NJ Avatar
Tim NJ Tim O
Cliffside Park, NJ, USA   USA
1978 MGB 41000 miles
I replaced the alternator with a rebuilt. seems to work fine until I put lights on. With lights I get a screech. turn lights off and it goes away. new belt and sprayed belt stuff but no success.
2nd problem is at 3500+rpm I get a loud vibrating sound from under the car. Sounds like it is near the muffler hanger (the one under the drivers seat). the exhaust system seems tight and hangs well, I can't get much movement at all/
ClayJ Avatar
Mt. Olive, MS, USA   USA
Alternator: A) belt not tensioned properly, B) belt not aligned properly, C) improper belt, D) new pulley improper for belt type.
Vibration: If not speed sensitive, the mid-exhaust pipe (or center muffler) between the down-pipe and the rear muffler comes very close to a notch in the fixed crossmember. You may need to pry exhaust away from that notch point or better center the pipe in the notch. If it's speed sensitive I would check the drive shaft phasing and u-joints.
Tim NJ Avatar
Tim NJ Tim O
Thanks clay,
The noise that the exhaust makes is hard to describe, it is not hitting the body. It is more like a loud buzz than a vibration, I don't feel anything just hear a racket.
riley1489 Gold Member Bruce H
In reply to # 3494550 by Tim NJ The noise that the exhaust makes is hard to describe, it is not hitting the body. It is more like a loud buzz than a vibration, I don't feel anything just hear a racket.
maybe loose baffles inside the muffler/resonator?
Check your ego Amigo!
RAY 67 TOURER Avatar
RAY 67 TOURER Ray Marloff
Fort Bragg, CA, USA   USA
1967 MG MGB "My Girl"
Make certain that the bracket, that goes around the downpipe and attaches to the transmission, is in place. The problem with alternator may be that the pulley wasn't tightened properly and is slipping under load. An impact wrench is needed to get it tight enough. RAY
ClayJ Avatar
Tim, hearing the vibration is a rattle smiling smiley I would look close at where it passes the crossmember and the support mentioned above that attaches to the downpipe.
Chalky Avatar
Chalky David White
Have you taken the centre console / gear surround apart recently. The four screws that hold the metal gear surround down are different lengths. The one that faces the front of the car is shorter than the other three. If there's a long screw at the front you'll hear a loud buzz and a banging noise - sounds just like the exhaust. It's the gearbox touching / hitting the screw.
BH Davis Avatar
Thompson, CT, USA   USA
How old is the front muffler? When mine was ready to replace the internal baffles came loose and rattled at idle but not at higher rpm. While opposite of your rattle in terms of rpm my guess is that this is the problem. You can try tapping on the muffler with a rubber mallet to see if it creates a rattle.
BH
garyd Avatar
garyd Gold Member Gary Dabrowski
Naugatuck, western Connecticut, USA   USA
1957 MG MGA 1500 "Long Gone"
1975 MG MGB
1976 MG MGB
Agree with the above. I had baffles come loose in a center muffler. Created a buzzing rattling annoying noise.
Maker of carb and choke brackets for MGB cars fitted with the SU HIF4 carb & later car HIF4 upgrades. Maker of the Air Filter Builder’s Kit, a compact and stylish alternative to Coopers Cans using economical, locally purchased air filter elements.
woodstock1 jim jensen
cleveland, USA   USA
....bad alternator from the rebuilder...have it checked..........
Tim NJ Avatar
Tim NJ Tim O
Thanks guys!
I took off the front exhaust strap and it stopped. Put it back on in a different spot where the pipe was a little fatter and and the noise is still there but not as loud.
Is there a purpose for that front strap?
In reply to # 3495835 by Tim NJ Is there a purpose for that front strap?
yes
this strap serves to secure the dual down pipe in line with the engine hence preserving the exhaust gasket/donut at the joint of cast iron header & down pipe. .
spikemichael Avatar
Ocean Shores, WA, USA   USA
1973 MG MGB "Freebie"
1974 MG MGB "Spike"
It should snugly clasp the exhaust pipe
Michael J. Caputo
Calendar Photo Submission Deadline: July 31! Email tips@MGBCalendar.com for FREE PHOTO TAKING TIPS! You can always call me at 978-249-5760 PST about Weber DGV Carbs, the calendar or just to talk MGB!
