Welp...this doesn't look good
MicroBrew412 Avatar
MicroBrew412 Mike A
Macomb, Michigan, USA   USA
So I took my '71 B out of storage last summer and have all the kinks worked out except that the water pump is making some noise so I planned on replacing it today. I drained the coolant and its a disgusting brown color (see picture.) The car sat in storage for about 12 years after being fully restored so I just added some water last summer to get it running. The car runs great right now and doesn't seem to have any noticeable problems when driving. Will I just need to flush it a few times or am I looking at something far worse? Fingers crossed...
IMG_1110.JPG    22.8 KB
chris Avatar
Pendleton, OR, USA   USA
That's just rust and such. No worries. Flush and refill with new 50/50 mix.
Used English car parts.
steve78b Avatar
steve78b Gold Member Stephen Brockwell
Elgin, OK, USA   USA
1978 MG MGB "Lilith"
May just be light rust from having only water in contact with the steel/iron in the block and head. I've done that before and just flushed it with Prestone flush then put in the right amount of antifreeze.
(I was typing while Chris was replying)
Steve stuck in OK
Love my MG.
Many are like it
........ no probably not.
Unless others are duplicating my mistakes.
Edited 1 time(s). Last edit at 2017-03-20 10:25 AM by steve78b.
HiPowerShooter Avatar
Oshkosh, Wisconsin, USA   USA
Flush, fill, run and drive.
Nothing unexpected there...
MicroBrew412 Avatar
MicroBrew412 Mike A
Ok I feel a little better now. This may sound really stupid but can I just put a hose in the thermostat housing outlet and run water through it?
In reply to # 3472679 by chris That's just rust and such. No worries. Flush and refill with new 50/50 mix.
BumbleB74 Avatar
BumbleB74 William Milholen
You can, but to do a better job buy some radiator flush stuff at your parts store, and follow the directions. Might want to do it a couple of times.
You'll be amazed you get out.
dipstick Avatar
dipstick Kenny Snyder
1941 Ford N-Series
1970 MG MGB GT "Pat's GT"
"... can I just put a hose in the thermostat housing outlet and run water through it?"
With the lower radiator hose off the hose will be helpful in the thermo (probably closed), and in the radiator. The bottom of the block water jacket is loaded with rust and will require flush chemicals to loosen.
Be safe out there.
Kenny
RAY 67 TOURER Avatar
RAY 67 TOURER Ray Marloff
Fort Bragg, CA, USA   USA
1967 MG MGB "My Girl"
Prestone makes an inexpensive kit that comes with a "flushing tee" that fits in your heater hose. Hook it up to your garden hose, turn on the water and wait until the water comes out clear. Add antifreeze. RAY
1969 MG MGC GT
