1973 MGB Fuse panel with relays
KTMLew Gail Taylor
Wendell, North Carolina, USA   USA
Finally about ready to mount. Doing this for someone else. They needed an alternator so had them order the Saturn swap that's been mentioned here about 100 times. Need one more relay for heater.
Edited 2 time(s). Last edit at 2017-02-16 02:18 PM by KTMLew.
IMG_20170216_144606327.jpg    33.4 KB
sandglowB Avatar
sandglowB Al Blosser
Uniontown, Ohio, USA   USA
Nice
Ahmed Avatar
Ahmed Ahmed EL Abasiry
Chestermere, Alberta, Canada   CAN
1958 MG MGA
Looks nice and compact.
Probably too late, but I would suggest adding extra, separate, fuses for the fuel pump and Overdrive (if present)
Edited 1 time(s). Last edit at 2017-02-16 04:30 PM by Ahmed.
KTMLew Gail Taylor
In reply to # 3451620 by Ahmed Looks nice and compact.
I intend to mount another fuse panel for the headlights. Can easily enough wire the fuel pump into that panel. I WILL go through and check AMPS draw on all circuits separately. Not sure if this car has OD? Also would like to either add fuse links or fuses to brown wires coming off starter main connection. The above is basically a knock-off of Eric's. Tried to buy his set-up but got no response. I've spent more than I'll get back building this one. Finally found the same fuse panel Eric used which is shorter than my original and fit the plate i wanted to use. Again...i didn't want to build my own. Hopefully he gets back to making them again in the spring.
riley1489 Gold Member Bruce Hopgood
In reply to # 3451636 by KTMLew I intend to mount another fuse panel for the headlights. Also would like to either add fuse links or fuses to brown wires coming off starter main connection.
Nice job. thumbs up
Not sure why you need to fuse the headlamps but go for it if it is a good idea. Usually a fused feed to relays would accommodate headlights, no?
Curiously the new panel you show houses the same number of fuses the 1973 came fitted with, just way tidier. cool smiley What do the two relays shown switch?
to do the "add fuse links or fuses to brown wires coming off starter main connection" see the link below this may do?
http://www.autosparks.co.uk/electrical-components/fuses-fuseboxes/strip-fuses-fuseholders/midi-fuse-70-amp-suitable-for-use-with-c-3012.html
I have always been mad!
gray Avatar
gray Graham Moore
how did you crimp your flag terminals? cheapest tool i can find is £££ and just for a terminal, just too expensive.
i am thinking a vice is the only sensible tool - but only when not under the bonnet.
G
KTMLew Gail Taylor
In reply to # 3451647 by riley1489
Nice job. thumbs up
I just don't like unfused hot wires. If you get in a wreck and pinch a wire the fuse keeps the car from burning . I know some people say never fuse a head light as you don't want one to blow on a dark night. Well...if the power wire shorts to ground the lights are going to get REAL dim real fast. Everything built last 25 years has one large cable for starter current and another slightly smaller (8-10ga) that powers everything else. The 8ga goes to fuse/relay panel. NOTHING leaves that panel unfused. That is what i plan to do.
sandglowB Avatar
Good plan. One night last year after I had done my upgrade my headlights went out. I had blown a fuse. After driving home with parking lights only, I discovered a pinched wire under the cowl on the steering column. Without the circuit being fused I would have had a much larger repair.
KTMLew Gail Taylor
In reply to # 3451832 by sandglowB Good plan. One night last year after I had done my upgrade my headlights went out. I had blown a fuse. After driving home with parking lights only, I discovered a pinched wire under the cowl on the steering column. Without the circuit being fused I would have had a much larger repair.
The set-up I'll build will have separate low & high relays and fuses. So if one blows have other circuit.
sandglowB Avatar
I had the relays fused, but I also had fused the feed to the headlight switch and that is where the short was, and why both relays had no power. As I said, the fused power supply to the switch saved me from a lot of damage.
gray Avatar
gray Graham Moore
as a matter of interest, did you consider micro relays? i am just wondering why one would not use them?
i have been planning a board similar to yours but space & therefore size is clearly an important consideration when locating an electrical board in the engine bay.
like yourself i had also decided to have dual relays for some circuits. initially i thought i would need to spread the board over 2 locations but with microrelays being half the size of a stock relay, that would not be necessary.
as far as i can see, a 30/40A 12v relay should do the job being small or large?
comments?
G
KTMLew Gail Taylor
OK. Gonna re-do. Going to separate the green wires at the fuse box. Blew a 10 amp fuse which runs signal light circuit which is piggybacked into back-up lights. Have a short in BU light circuit. Lights appear to be new. Probably just run another 4 circuit fuse panel.
In reply to # 3473045 by KTMLew OK. Gonna re-do. Going to separate the green wires at the fuse box. Blew a 10 amp fuse which runs signal light circuit which is piggybacked into back-up lights. Have a short in BU light circuit. Lights appear to be new. Probably just run another 4 circuit fuse panel.
Shorts will do that. winking smiley
My 1973 doesn't have 'BU' light circuit? in fact the only 'B' circuit is a BW used for that crazy dash warning light for failed brakes.
More fuses certainly can't hurt! thumbs up
rntanner Avatar
rntanner Silver Member Roger N. Tanner
Oxnard, CA, USA   USA
1970 MG MGB
Your local auto supply should have the relays.
Roger N. Tanner
Professional Engineer, Retired
KTMLew Gail Taylor
After thinking about this more, I suspect i don't have the wiring connected to the reverse light switch, think i have it connected to the timing advance switch (or OD if applicable-this car doesn't have OD). I'll start there. Jack car up and check operation of reverse switch first. The wiring was burned up and I made a harness.
