Complete Engine Change
oldmod Mick Wallington
Ashburton, Canterbury, New Zealand   NZL
1977 MG MGB "Bluebird"
Help, I need some advice.
Have decided to blue print another engine for my "77 MG. I could go through the whole execise of rebore, pistons and rings, head upgrade etc.
OR I could buy a 2000cc stage 2 Performance unit. OR a stage 2 head on a rebored 1.8 to 2000 with a new cam and carbs.
Does any know the best way to go about this convertion.
Mick
the omega man Avatar
the omega man phil wilkins
Biggest I've seen is 2100 cc from the MGOC
Welcome Mick. If the following that I went through helps... for quite sometime I thought about importing a full motor as Omega alludes to from MGOC. In the end I kept mine and balanced it so not total blueprint. The deciding factors were that despite all my changes I really wanted to keep my original block. I don't know if you have the wherewithal to diy. I didn't so I had mine professionally done. I stripped it but a shop tanked it and bored it to match the pistons they had (I've only gone to +40) plus they did the crank and had it all balanced. I put it together with a head I imported from Peter Burgess (well Mechspec Dave). Doing it that way was about breakeven with importing a full motor (they are not readily available here) and I saved myself the hassle with Customs.
Edited 1 time(s). Last edit at 2013-05-22 07:39 AM by MGB567.
MGST Avatar
MGST Andrew Metford
Shipping a whole engine from England to NZ will not be cheap!!! And those engines aren't exactly cheap either. I think with what it would cost you to get an engine sent from England you could rebuild your one very nicely indeed. The MG Service Centre ( Christchurch I think ) should be able to sort you out.
Bear in mind that a 1950 engine is the stock stroke with a 0.135" overbore. The MGOC 2100cc is the 0.135" overbore plus a stroked crank to get the extra 150cc. I don't know what sort of driving you intend to do, but the B engine is hardly a bigger revver as it is, and increasing the stroke won't help it. Unless you intend to seriously race it, a 1950 with a fast road cam, clean up the head, balance everything, and the obvious re-jet of the carbs will keep most people happy for many years, even with the occasional track day.
1973 MG BGT - Harvest Gold / Black interior
1974 MG BGT - Bracken / Autumn Leaf interior - http://forum.britishv8.org/read.php?13,11702
