Any love for this type of spotweld cutter?
Posted by NOHOME
NOHOME Avatar
Peter Plouf
London, Canada   can
Going to do a set of floors in the next week or so. Traditionally, I don't use anything more sophisticated than a 1/8" and a 5/16" drill bit to drill out the spotwelds.
I hate the "hole Saw" type spotweld cutters because they wear out fast and leave an island of metal that needs to be ground away. Plus they require that you drill a 1/8" pilot hole anyways.
I have seen this other type of cutter that looks like it would do a decent job. Have not tried them because it would involve mail ordering and they are not chap 15-27 bucks a pop. If I buy 4 of them, I would have up to $100 just into the bits.
Are they worth it?
On another note, since I am doing another set of floors, if anyone wants any pictures of a particular process for an upcoming project of their own, feel free to pre-order!
Pete
dtownsend Avatar
David Townsend
Rutland, Vermont USA, USA   usa
I bought a couple of these from Eastwood for my sills and thought they did a decent job and didn't seem to wear all that fast.
balloonfoot Avatar
Lloyd Faust
New Mexico, USA   usa
1964 Porsche C Coupe
1967 MG MGB "MAX"
1985 Chevrolet Corvette "EASY 1ST"
1986 Chevrolet Corvette "Gas Mileage Special"
1989 Chevrolet Camaro ""I Rock""
mine last for years.......you know why Peter..devil smiley
“Better to remain silent and be thought a fool than to speak out and remove all doubt”.
- Abraham Lincoln
balist Avatar
steve bali
Vernon, BC, Canada   can
Hi Peter,
I purchased these cutters from KMS Tools for $14 each they come in two sizes work very well and last a long time
British Classics Avatar
Brad Pace
Deep Creek, Wa., USA   usa
I have used that one and did not care for it. It took a lot of pressure, wandered and broke. I have tried all manner of spot weld cutters and have quit them and gone back to using a carbide ball burr and narrow cut-off in a die grinder. One panel will always be sacrificial so grind from that side and look for the dark ring that shows where the spot weld stops. Attached is a pic of my current project and you can see how many welds were cut using this method.
Morrison BE 026.jpg (38.2 KB) –
Morrison BE 013.jpg (45.2 KB) –
Mar '013 003.jpg (45 KB) –
Mar '013 030.jpg (47.9 KB) –
Benny Avatar
Ben E
San Diego, CA, USA   usa
Peter,
A few months ago, Lloyd posted a picture of a spot weld drill that has effectively has a built in depth-stop. They appear to use a similar cutter to the one you posted.
I found one of those drills pretty cheap on eBay, but haven't had a chance (or need) to use it. You're welcome to give it a try if you'd like....just cover the shipping, and you can borrow it pretty much indefinitely.....it even has a good cutter in it.
Dave Craddock
Redford (Detroit), Mi., USA   usa
Pete, it looks like in the worst case you could resharpen it yourself, might have to dress up a narrow
grinding wheel.
Dave
Preform Resources.com   – Redford(Detroit) Michigan USA Preform Resources,Inc./Dave Craddock, MGB composite parts, body kits ,front and rear valances, stock and RV-8 bolt on hoods , composite parts that FIT!Complete design & build services. 313-533-2457 http://preformresources.com/ preres@sbcglobal.net
NOHOME Avatar
Peter Plouf
London, Canada   can
In reply to # 2305818 by Benny Peter,
Ben:
That is a kind offer. Sound like you are going down the "No More Rusty Cars for me road!"
I am actually pretty good with the two drill bit way technique. I buy 4 small and 2 large bits for the typical job.
I think I will see if my paint supply guy can order some for me. Not being a pay-pal person I have a hard time ordering stuff on line.
Benny Avatar
Ben E
In reply to # 2306041 by NOHOME Ben:
HA.....apart from a '66 Ranchero I bought with rusty floors when I was 15, I've never bought a rusty car.
At one point, I had convinced myself that my Iris Blue '65 needed new floors, but after looking at them again and again, I've determined that the weak spots are so small, that they can be carefully patched with very acceptable results.
The offer stands if you want to give this thing a whirl.
Jim Macaulay
Concord Ma., USA   usa
Lloyd, That was just flat wrong but not necessarily mean spirited!
halghultman Avatar
Hal G Hultman
Wayne, MI, USA   usa
1972 MG MGB "The "B""
Peter, when I replaced the sills and floor pans in my '72, I used the BLAIR PREMIUM SPOT WELD CUTTER KIT # 11082. Although this is the hole saw type that you don't care for, I was really happy with it's performance. I did the entire driver side sill replacement and floor pan using two bits. I would not have needed the second bit had I not got impatient and overheated the bit, thus losing the temper of the cutting teeth. With this cutter I can easliy cut out a weld in about 10-12 seconds. Remember that these old cars have very soft mild steel unlike the cars being built today and very little pressure is required. The cutter always left a clean hole that looked like it had been punched out. No grinding neccessary. Lastly, you need not drill a 1/8" pilot hole as a center punch is all that is needed to keep the pilot from drifting. The kit comes in a nice compact storage case and comes with (1) arbor, (2) pilots & (3) 3/8" cutters.
72bwhite Avatar
Larry McKinney
Thousand Oaks, USA   usa
Peter that looks like a butterfly or brad point drill bit just stubbier, if it's hss or cobalt they should wear well like any good drill bit would think you would only need one maybe 2 at the most
carlheideman
USA   usa
Peter,
We use the Blair spot weld cutters as mentioned above (aka rotabroach) on customer cars. We usually drill a 1/8" pilot, then use a 5/16" cutter. I've used the style of bit you show in a Snap-On spot weld cutting tool I have ($$$$), but find it's a bit slower and more expensive. The Blair replacement cutters are about $5 each and we get about 200-300 spot welds cut before they dull or break.
For whatever type of cutter you use, make sure to clean/wire wheel as much rust away as possible and lube the bit. Rust dulls bits very quickly, so the cleaner the area, the longer the bit lasts.
Also, for floors, we rarely drill out the spot welds. We usually use a 3" cutoff wheel on a die grinder to weaken the spot welds, then use an air chisel to pop the welds loose and cut out the floors. I can get a floor out in less than an hour that way. I wrote a story about the method for Classic Motorsports 7-8 years ago when I did the Modern Midget's floors.
Have fun!
Carl
http://www.eclecticmotorworks.com/
Edited 1 time(s). Last edit at 03/07/2013 08:58AM by carlheideman.
NOHOME Avatar
Peter Plouf
London, Canada   can
In reply to # 2306596 by carlheideman Peter,
Have fun!
Carl
Carl:
I keep hearing about and trying the grinding wheel/cutter method to remove panels, but for some reason it seems like a lot of work with a lot of mess and noise.
I will see if I can find the Blair spot weld cutters locally as they would have to be a quality tool if you are using them. The ones I have used have all left a center island after the cut that needs to be ground down.
Adrian Page
Nova Scotia Canada, Canada   can
I'm getting one of these for the next one I do.
Benny Avatar
Ben E
Adrian,
That's nearly identical to the drill I got on eBay.
NOHOME Avatar
Peter Plouf
London, Canada   can
The spotweld drill machines are great, but they wont do you any good on the floor panel replacement. Maybe a mag drill is the answer!
Adrian Page
In reply to # 2306817 by NOHOME The spotweld drill machines are great, but they wont do you any good on the floor panel replacement.
Why do you say that?
Benny Avatar
Ben E
I disagree. If you cut out the majority of the floor pan, I see no reason you couldn't go around the flanges with one of those drills to remove the remainig strips.
Mark Jones Avatar
SW, Ontario, Canada   can
1970 Triumph Spitfire MkIII
1995 MG F "Barney"
Peter, I've been using the cheap hole saw type that you hate. Although not perfect I find they work better than the one you provided a picture of. Although I too drill a 1/8" pilot hole, I don't find this to be problem; I just keep two drills at my side when drilling out spot welds, an old B&D with a double-ended 1/8" bit chucked into it, and a second one with the hole saw type bit.
Canadian Modern MG Rover Car Club - www.cmmgrcc.org
