Folding Frame or stow-away frame?
Jonas1 Avatar
Jonas1 Doug W
Gainesville, GA, USA   USA
One more opinion topic,
I've got a Stow-away frame for the top but, I'm considering switching to a folding frame, specifically the black 1971-80 frame. Which is better? I've also noted on Prestige auto tops http://www.prestigeautotops.com/acatalog/mgb1962-80_originaltops.html , that they sell the stow-away top that also fits the gray folding frame for the 1963-70 cars. That way I could buy the top get it fitted to the car and later find a gray scissor frame. Does anyone have any experience with this top?
Thanks,
Doug
SCL Avatar
SCL steve langford
melbourne, USA   USA
I have switched to the stow away much easier to put it in the trunk or leave at home. tops seem to interchange, mine did
Tonytele Avatar
Tonytele Tony Ceglinski
Nimmitabel, Australia   AUS
1967 MG MGB
1967 MG MGB
Hi ... I have a '67 B which has a fold way frame ... Fantastic! You can do it all from the drivers seat. Say your driving along minding your own business, then suddenly up head it's pissing down .. simply pull over and in about 45 seconds you have your roof up and don't get soaking wet like that guy who has to get out, go to the boot (trunk in your lingo) and get out the bag and build the frame and then put the cover over ... Nah, not for me. But hey, we're all different! Regards from down under.
treardon58 Avatar
treardon58 Tom Reardon
Wichita, KS, USA   USA
1967 MG MGB GT
1972 MG MGB "Kimber"
1974 MG MGB    & more
I have to say the best quality / fitting top is Robbins. They are very close to the factory top in fit and finish but a heavier ply material. They are fairly simple to install too. Always opt for the zip out rear window. I stupidly put a fixed rear window on my '72 and nearly died of heat stroke that summer. In my opinion, the Prestige tops are over the top. They are beautiful but way too much money for me. I always feel like you can easily upgrade these cars too much and lose their charm. I have owned cars with every variation of frame. My '69 had the stow away unit that was great until I needed the boot for something or was caught out in a sudden downpour. The early folding unit was deadly. The top collapses inward and can pop you in the temple if not careful. It's quite awkward too. The late model Michelotti frames are by far better in terms of functionality. If you want a grey frame, it's easy to repaint. If I had to fault it, I'd say they are not as convenient as a Fiat 124 spider or Miata top that is a simple push back, pull up affair without the lift a dots and all. All my opinion. Ultimately, pick the combination that makes you happy and achieves your goal. Good luck.
SURFIT Avatar
SURFIT Gold Member Mike Schultz
Zionsville, IN, USA   USA
Went from fold-away to stow-away (lived in SoCal at the time and never used the top).
Now, I use it in the mid-West. I still like the idea of being able to completely remove the top
from the car. Plus, I have a zip-out rear window which I believe is only available in the
stow-away version (a nice top-feature to have).
JPWinOK Avatar
JPWinOK James Wellman
Lawton, OK, USA   USA
My fold away has a zip out rear window
MSGDLD Avatar
MSGDLD Gold Member Dave Densmore
North East, OH, USA   USA
1974 MG MGB GT "Mabel"
1980 MG MGB MkIV
Depending on how you use your car, a stow away may work for you. The car does have a nice clean look to it that way, and leaves the back open. I think it's harder, and takes longer to put up than the MGA's top did. Besides that, do you really want to store your new top with the spare tire and tools?
If however, you drive it, aren't afraid to get the car wet, and plan on taking some longer trips with it, the stow away is a pain in the arse. The last time I had a stow away was on a 65B I owned in 1974. I switched that PITA soon after I got it, and never looked back!
BTW,zip out windows are available in either style, and IMHO are worth double the difference in cost.
Just my opinion, but I'm usually right! :thumbs up smiley
78mgb White Wonder 78mgb
apple valley, MN, USA   USA
1978 MG MGB
I had a stowaway frame on my 1963 Austin Healey Sprite; I hated it. Took about 10 minutes to put the top up.
I have a fold away fram on my 1978 MGB, I hate it. Takes about 30 minutes to put up.
So having experienced both I would vote for the stowaway frame. I will keep what I have but the stow away frame is easier to use.
MSGDLD Avatar
1980 MG MGB MkIV
White Wonder,
If it's taking you more than a couple minutes, in other words, longer than a stow-a-way to put up a folding top on your 78 B, their's something wrong. Could the frame joints be loose, or rusted too stiff?
aeronca65t Nial McCabe
an, NJ, USA   USA
1967 Austin-Healey Sprite "Spiffy"
My '69 MGB had the "scissors" type folding frame and I switched to the old-style packaway (stowaway) top. That folding top seemed to be really hard on the top material, plus it was clumsy to operate.
My MGB lives in a garage and the top is rarely up in the Summer. In the late Fall, I put the top up and it tends to stay up until early Spring (and I do very little driving in the cold weather anyway).
I love the clean look, but I'd agree that if you had to put it up and down a lot, it's a hassle. I only drive the car about 700 miles a year, so this is no big deal to me.
I also have a Miata and '73 Midget. The folding tops on those cars are great when the weather may require a quick cover.
The Miata is especially nice; even with a Hard-Dog roll bar, I can drop the top from the driver's seat.
npmccabe.org
kevin58 Kevin Profitt
Saginaw, MI, USA   USA
I've got a finger pincher too on my '69. Hate it... absolutely hate it. Fortunately I only have to deal with it twice a year.
1978 MG MGB
In reply to # 2239494 by MSGDLD White Wonder,
Going up or down takes a minute or two, but putting the lift-a-dots on takes a lot of time. If the lift-a-dots would align properly, it would take less time. The cooler the weather, the harder it is to get them to snap. When I installed the top, it seemed that it was cut too short (other people have complained about the same problem). So the top is real tight when it is up. Since I do most of my driving in nice weather, the top is mostly down. My experience with my 1963 AH Sprite with the removable top was much easier going up and down. I am sure if the top was sized right, it would make a difference but getting a new top is not a priority to me.
EW Chapman Avatar
EW Chapman Earl Chapman
Ottawa, ON, Canada   CAN
My 69 originally had a fold away top, but like many others, I switched to a stow away when I bought a new top. The stow away is great as it leaves a lot of space behind the seats and is not a big deal to put up. I rarely have the top up during the summer, but occasionally when I do get caught out in the rain, it's amazing how quick you can get a stow away top assembled and in place with the top secured. Sounds like a competition one could have at an MGB gathering.
MSGDLD Avatar
1980 MG MGB MkIV
White Wonder,
Gotcha. After I wrote I thought about a tight top, or lift a dots. I admit, been there and done that, it's miserable, but for me it's always been on an old top. Hmmm, maybe it's because I've never had a new top. I can also understand why you wouldn't want to replace the top when it's in good shape. BTW, I understand that the vinyl tops have more problems with temperature affecting fit than with cloth. Also with tops that have gone long periods without being put up.
Can I ask what brand top it is? Sooner than later I will have to get one for the 80B. Sounds like a good brand to avoid!
1978 MG MGB
In reply to # 2239720 by MSGDLD White Wonder,
I will try to find the paperwork on the top. I bought the top a long time ago from J.C. Whitney and did not install it until recently. It had a lifetime warranty but Whitney was really fussy about honoring it. The first one that I received had a zippered back window and the zipper broke, so I sent it back. When I went to install it, I could see that the top was cut short and so I had a hard time installing it. I thought about returning it but decided that since I had if for so long that it was not worth the effort of returning it. I do remember that it was made in the USA and that the company appears to still exist.
