Rivergate 5 Speed Conversion - Documented
Moonshine Avatar
Moonshine Bob Berfanger
New Melle, MO, USA   USA
1977 MG MGB "Beatrice"
Thought I would start a thread documenting my Rivergate 5 Speed conversion. What I'm working with is a 77 MGB and a 81 Datsun 280z 5 speed transmission. The engine has been pulled and is setting on one of the 4 car dollies.
IMAG0712.jpg    32.2 KB
IMAG0714a.jpg    72.5 KB
Moonshine Avatar
First order of business was to remove the back plate. At this point it’s a good time to inspect the rear seal surface. If need be you may want to install a Speedie-Sleeve.
IMAG0718.jpg    48.7 KB
IMAG0720a.jpg    66.9 KB
Moonshine Avatar
Next, install the new Pilot bushing (included in the kit). The new bushing is the one on the left. This was a good snug fit.
IMAG0725.jpg    33.5 KB
IMAG0734.jpg    47.7 KB
Moonshine Avatar
Installation of the new back plate included in the Rivergate kit.
IMAG0737.jpg    30.5 KB
29desoto Avatar
1953 MG TD
1977 MG MGB "Ole Yeller"
1979 MG MGB "Kermit"    & more
Robert, I really could have used this as a confidence builder a year ago! Let me know if you have any questions. It's really pretty easy. And the kit is one fine piece of work. Every single part on mine fit without any fiddling.
You're gonna love it! Seventy is the new 57!
Wayne Sanders
Rose Lodge, OR
(TD 4288)
77 MGB - Four tone paint -Pertronix - hood props - cheap tires - new springs all around - mixture of poly and rubber bushings- fuzzy seatcovers - stereo out of old F150 pickup -runs flawlessly and drives nice.
53 TD Mark II - a work in progress.
Moonshine Avatar
Installation of the new Flywheel (include in the kit) and the original starter. You can send your flywheel in as a core or pay $100. My starter and flywheel were a little snug and the starter would not engage. Called Rivergate and they said they haven’t had any reports of that since they had updated their tooling. I opened up the holes on the starter and the back plate and was able to achieve a nice mesh.
IMAG0773.jpg    29.9 KB
IMAG0765.jpg    32.1 KB
Moonshine Avatar
Next, was the removal of the contact plate from the Pressure Plate. Since the Datsun tranny has a throw-out bearing, its no longer needed.
Well, that's all for now, I'll try to post some more tomorrow.
IMAG0746a.jpg    64.1 KB
IMAG0749a.jpg    62.2 KB
Moonshine Avatar
In reply to # 2201952 by Moonshine Installation of the new back plate included in the Rivergate kit.
I forgot to mention that the back plate came with the rear seal installed.
Idasix Avatar
Idasix Dave - Lauretta Smailes
Washington State, USA   USA
1975 MG MGB "Red Rider"
Robert thanks for posting the pictures. I converted to the Rivergate 5 speed last year. It was one of the best decisions I ever made on that car. The gear spacing seems perfect and having a 5th. gear is great. I would do it again anytime.
Dave
jfrankr Avatar
jfrankr Jan Rische
Grayslake, Il, USA   USA
1966 MG MGB
OK now there aren't any dumb questions, so..... The Datsun Tranny has a throw out bearing so the contacty plate on the pressure plate isn't needed. I'm drawing a blank on the engineering with this.
29desoto Avatar
1953 MG TD
That's easy once you look at the thing. The MGB throwout bearing is a carbon faced block. If it met up with the fingers on the pressure plate, it probably wouldn't last ten seconds. It would be chewed to bits.
Put that nice, smooth facing on the fingers of the pressure plate, and it's carbon against smooth steel.
With the roller bearing, it turns instead of just pushing and staying still.
Wayne Sanders
Rose Lodge, OR
(TD 4288)
Moonshine Avatar
Install the new clutch disc (supplied with the kit) and the modified pressure plate. The pilot tool was also supplied with the kit.
IMAG0776a.jpg    61 KB
IMAG0779a.jpg    66.6 KB
Moonshine Avatar
The next 2 steps are preparing the Datsun transmission.
Install the new rear seal (supplied in the kit) on the Datsun transmission.
Remove, clean, and inspect the Throw-Out bearing. There are 2 springs on the fork. To remove the bearing, push the fork toward the opening. This will disengage the spring from the bearing carrier (right arrow). Slide the bearing and carrier off. Now just pull the fork forward to pop the spring (hidden under fork) off the post behind the fork (left arrow.
Lube the shaft and carrier and reinstall. Lube the fork pivot and reinstall. The fork boot is not shown in the graphic.
IMAG0752a.jpg    57.1 KB
Moonshine Avatar
In order to get the shift lever to past through the center of the tunnel, some modification needs to be done to the shift lever and the flanges that hold it.
There are 2 flanges that hold the shift lever. The driver’s side flange needs to be ground down so that the modified shift lever has the required range of motion.
The shift lever will be modified after the motor and transmission are installed back in the B.
IMAG0762a.jpg    59.3 KB
IMAG0791a.jpg    47.5 KB
Moonshine Avatar
Now were ready to bolt up the motor and transmission.
IMAG0792b.jpg    49 KB
