Brake Master Cylinder Replacement
MGB Legacy Avatar
MGB Legacy Bradley M
Phoenix, Arizona, USA   USA
1976 MG MGB
I am going to be replacing the Brake Master Cylinder on my 76 MGB. I was looking at the haynes manual. Haynes says to drain the clutch Master and Slave as well as the Brake Master for the Brake Master Replacement. On a 76 B, aren't these two independent systems attached to opposite ends of the Vacuum Booster? I have searched the forums and google, and haven't found any complete information on this subject. The Clucth Master and Slave were just replaced a few months ago by the PO, so I don't want to have to mess with them if I don't have to. I am also replacing all other brake parts, such as wheel cylinders, pads, shoes, calipers, rotors, hoses, hardware, etc. at the same time. If anyone has done this and has advice, please chime in.
Brad
1976 MGB
The right tool is worth a thousand four letter words.
darkleaf Avatar
darkleaf Gold Member Leif Jacobsen
Goleta, CA, USA   USA
You don't need to mess with the clutch hydraulics.
Steve Mc Steve Mcnary
USA   USA
On the vacuum boosted systems you don't have to remove the clutch hydraulics. If you are replacing only the brake master (not the booster) you don't have to do anything with the pedal box.
On comment though, you should inspect the brake pedal pivot and booster push rod and clevis pin for wear. If these are worn, then it's best to pull the whole pedal box out. In this case, you can remove the clutch pedal clevis pin and unbolt the clutch master from the box. You can then withdraw the entire pedal box and leave the clutch hydraulics unbroken.
tomkatb Avatar
tomkatb Larry Baygents
Dayton, Ohio, USA   USA
1963 MG MGB
Make sure the parking brake is 100% as well. Check that compensator if you have one. Brake cables are cheap.
I had a catastrophic brake failure last summer. It happens.
L.W.(Larry)Baygents
63B
77 Spit
MGB Legacy Avatar
1976 MG MGB
Thanks all for the good advice. I have E Brake adjustment on my list and have new rear brake adjusters in hand ready to go in. Wish me luck.
Brad
1976 MGB
RobbyM Robert Milne
Guelph, Ontario, Canada   CAN
You will have to disconnect the clutch metal line fron the clutch master in order to move the pedal box. But for just the brake master then leave the pedal box alone.
RichPho Avatar
RichPho Joe P
Richmond, USA   USA
1980 MG MGB "M-Gizzle"
Easy job... If your bay is painted nicely, remember that brake fluid will eat some paint! Invest in a decent bleeder... Makes a world of difference.
MGB Legacy Avatar
1976 MG MGB
I know that Brake Fluid is deadly to paint. And unfortunately I just repainted the engine bay. What Bleeder Kit brand has worked well for everyone?
Brad
1976 MGB
chris Avatar
Pendleton, OR, USA   USA
For brakes, I use a hose and bottle at each wheel in turn rather than a bleeder. Use care in pouring, have warm soapy water on hand to flush any spillage off the paint, and you'll be fine.
Not just for MG parts. Check out the Vendor Market page for ever changing specials.
tomkatb Avatar
1963 MG MGB
The Motive power bleeder is a joy to use.
My wife bought it for me after one of the episodes.
L.W.(Larry)Baygents
63B
77 Spit
