hanging and adjusting doors
Posted by tonydick
tonydick Avatar
tony C
sparta, USA   usa
I was given this 1980 MGB so I am having some trouble with some parts figuring out where they go and others with tricks with mounting. Right now it is the doors. First one door was on but not adjusted right. the flat screws are tight and I can not find the tool to loosen them so I can adjust the door. I also need new screws for the other door, the originals are missing.
HELP, TONY
29desoto Avatar
Wayne Sanders
Outside Otis, OR - in the woods!, USA   usa
1965 MG MGB V6 Conversion "Tubby"
1977 MG MGB "Ole Yeller"
1979 MG MGB "Kermit"
1984 Chevrolet Corvette "The Green Weenie"
1994 Chevrolet S10 "Lil Red"
Tony, at least you got it at the right price. It will only be a money pit instead of a BIG STINKING MONEY PIT! smiling bouncing smiley You gotta have a sense of humor around here!
Get the screws from Moss Motors. Then go up to the search box in the upper right hand corner and type in "door adjustment". Initial search is only 30 days, you may need to extend it.
You'll find some help there. Also note, these are Pozi screws. Get the right driver bits and don't chew up the new ones!
Wayne Sanders
Rose Lodge, OR
77 MGB - Four tone paint - some kind of electronic ignition - hood props - cheap tires - new springs all around - mixture of poly and rubber bushings - original exhaust - fuzzy seatcovers - stereo out of old F150 pickup - virtually no rust - right front wrecked and semi well repaired - just about right for me!
79/65 MGB - Tubby - Carmine Red - V-6 - T-5
Going to do this one more right, less rat rod!
Jim Gevay Avatar
Circle Pines, MN, USA   usa
Tony, the 6 screws per door that mount it to the hinges are Pozi-drive heads. A good tool to use is a 3/8" drive #4 Pozi-drive for your ratchet. You can get one from someplace like Graingers and it's about $7.00. it makes working with the screws a snap, now adjusting them to where you want them, takes trial and error, and patience
Early 1974 MGB with OD, SU HIF's, 72 spoke chrome WW's, Schlemmer Pertronix, DuBois fuel pump, Limey's relays.
herculesmgb1971 Avatar
gerard boulanger
Hercules, CA, USA   usa
Maybe also time to check if the hinges got too much play... Expensive parts, but worth it to get good body alignment.
Gerard
gerard boulanger
I forgot the pic
Barrie Braxton
Sunshine Coast, Australia   aus
http://www.mgexperience.net/phorum/read.php?1,1688474 - #3 here. Note that if you're not into o/e you can use hex head screws to replace the posidrives. Perhaps not as neat looking but perhaps more practical.
CKD 11/66 first registered 8/5/67 owned since 3/77. Undergoing nut and bolt restoration. Tartan Red (now). 18GB +40 balanced with almost all new internals. Peter Burgess big valve fast road head. Piper 285. TT exhaust. ARP everywhere. 123 ign. Needham 4synchro c/r box. Stock rebuilt/replaced suspension. Superpro bushes. New brakes all round including all pipes in SS flex. Interior redone. CAMS approved roll bar and side bars. Lots more. Hybrid of o/e and show/fast road car. Not for sale - it's my toy!
Steve Lyle Avatar
Tulsa, USA   usa
Here's what I've learned about MGB doors, including 'encouraging' the old screws to come out..
http://www.mgexperience.net/journal/Steve+Lyle&PageID=1#jid-6979
Documenting my project in my journal at http://www.mgexperience.net/journal/index/Steve+Lyle
Greg Clifft
Dardenne Prairie, MO, USA   usa
Steve,
Great write up. I didn't realize I could leave my doors on during sill replacement. That will be a huge help.
Thanks for sharing your experience.
Barrie Braxton
So Steve you only gave a small % of your experience - see my #6 which leads to you at #3. Now I'm going to have to go back and read your journal and see what I may have missed - luckily my doors aren't hung yet (are yours Melbaver?).
tonydick Avatar
tony C
sparta, USA   usa
Thanks, I just ordred the bit. i will work on the other stuff untill it gets here. I am preping for paint.
TONY
melbaver Avatar
Chris Howells
Broadwater NSW, Australia   aus
1968 MG MGB "Moneypit"
Barrie, hung but yet to be furnished and therefore adjusted, can't put wings on 'til that happens, then more adjustment.
Chris Howells
1968 MGB Purchased already dis-assembled which is why I'm often ignorant about what some parts are, and even more ignorant of where they go.
j-blueridge Avatar
Jamie Bourland
C'ville VA, USA   usa
1968 MG MGB GT "Antichrist"
Years ago I bought a Craftsman hand impact driver tool and a Pozi bit just for removing the door screws. Used it all over the B for getting screws loose.
http://www.sears.com/shc/s/p_10153_12605_00947641000P
I have air tools now but still use the old hand tool too.
Barrie Braxton
Melbaver I've done it the other way - wings fitted (splash guards removed) but I do know my doors fit because they were trial fitted before painting. Doors still where you saw them (been doing other things) and soon to be have something done to try and prevent cod as discussed here recently. I figured fitting doors can wait until all interior fitted as well as the windscreen - less chance of bashing them.
