truing my wire wheels
1972mgb0 Rich L
Owings Mills, USA   USA
HELP!! Does anyone know where I can get my wire wheels trued in the metro Baltimore area?
Thanx for your help.
j-blueridge Avatar
j-blueridge Gold Member Jamie Bourland
C'ville, C'ville VA, USA   USA
1968 MG MGB GT "Antichrist"
Maybe call motorcycle shops to get leads?
Fairfield, CA, USA   USA
it is going to be expensive. as expensive in most cases as buying new wheels.
SUs, Datsun 5-speed
DaSpyda Avatar
DaSpyda Don Alexander
Lakeland, FL, USA   USA
Maybe he means "balanced".
Like, with weights...
Don
1970 MGB
1972mgb0 Rich L
Wheels are balanced.Have tires with less than 4,000 miles. I get a vibration at 3500RPM when I'm on the hiway, reduces significantly at 4000rpm. I've owned the car since 1991 and the wires have never been trued.
tweetymp4 Silver Member Michael Philpott
San Diego, USA   USA
I have at least one wire wheel with loose spokes, it has been a gigantic PIA. Not quite sure what to do. I'm really getting tired of dealing with the wire wheel BS. I'm really inclined to convert to minilites. Just not sure if I want to convert the hubs/axles or get minilites with the knockoff hubs.
DaSpyda Avatar
In reply to # 2129453 by 1972mgb0 Wheels are balanced.Have tires with less than 4,000 miles. I get a vibration at 3500RPM when I'm on the hiway, reduces significantly at 4000rpm. I've owned the car since 1991 and the wires have never been trued.
It could be an issue with a tire and/or the previous balancing, anyway. Make sure your spokes are solid first, of course.
Find a place that balances the tires "on the car" and who shaves a little tread to obtain that balance. I had the same problem on another car and it was smooth as glass from 0-115 after the treatment.
Don
1970 MGB
RAY 67 TOURER Avatar
RAY 67 TOURER Ray Marloff
Fort Bragg, CA, USA   USA
1967 MG MGB "My Girl"
It has become a lost art. Having worked in a motorcycle shop for years, almost all of what came in had wire wheels. I re-laced an awful lot of them and each proved to be time consuming in getting them just right. With new spokes, it's not that difficult a job, but when you try to break loose nipples and spokes that haven't been disturbed in decades, you had better have a lot of spare spokes and nipples on hand. RAY
bpaquette Avatar
bpaquette Bob Paquette
Grand Prairie, TX, USA   USA
In reply to # 2129498 by DaSpyda
Your B goes 115 MPH. Really??
Bob
GTgeezer Avatar
GTgeezer Lynn Kirkpatrick
Columbia City, IN, USA   USA
Rich
Lift the wheels off of the ground (safely) and use something to hold a screwdriver or pointy thing securely next to the rim, where wheel weights go. rotate the wheel slowly and watch for side-to-side wobble and up and down hop.
I think the spec is no more than 1/16" for each direction, but I may be wrong. This will give you an idea how bad the RIMS are.
forestghost07 Avatar
forestghost07 Marco Sinai
FL, USA   USA
1972 MG MGB GT "Viajero"
1999 Chevrolet Blazer "Works For Gas"
Hi Rich, may I suggest you get in touch with Allen Hendrix, Hendrix Wire Wheel, Greensboro NC. (on right in pic 1)
www.hendrixwirewheel.com
He's not terribly far from you, and he fixed my B's wire and innertube problems for good; I went out of my way after MG2012 for his services ... well worth the trip. 4 wheels trued, tires shaved, balanced, NO shimmies all the way to flat out now! He's the best.
~ Marco and Viajero ~
IMG_2272.JPG    47.2 KB
IMG_2273.JPG    61.4 KB
IMG_2274.JPG    50.7 KB
tkamd73 Avatar
tkamd73 Silver Member Tim Bradley
Menomonee Falls, WI, USA   USA
Faced the same situation a few years ago. Gave up and finally bought some Dayton 72 spoke tubeless wires, which solved all of my wheel issues, and has probably saved me a lot of time and frustration since. I can only get my B up to 108mph. Tim
DaSpyda Avatar
In reply to # 2129656 by bpaquette
In reply to # 2129498 by DaSpyda Find a place that balances the tires "on the car" and who shaves a little tread to obtain that balance. I had the same problemon another carand it was smooth as glass from 0-115 after the treatment.
Bob
Nope, it was on my MR2 Spyder.
Don
1970 MGB
Edited 2 time(s). Last edit at 2012-07-26 08:12 AM by DaSpyda.
balloonfoot Avatar
balloonfoot Gold Member Lloyd Faust
Southlake, TX, USA   USA
In reply to # 2129453 by 1972mgb0 I've owned the car since 1991 and the wires have never been trued.
Truing the wire wheels is not a "routine" thing to do. Depending on what part of the country you live in, you may break most every spoke you try to adjust. Break more than a few and you are better off getting a new wheel.
Spin the wheel....if it is in true, it is not your problem.
Gromit Avatar
Gromit Larry Heaps
Street, MD, USA   USA
1974 MG MGB "74 Moss"
Swap rear tires with front tires and see what happens.
