MG-2013 is only 59 days away! · Corvallis, OR · July 17–21, 2013 · Visit MG-2013.com or the MG-2013 Forum for more info
lower gasket on steering rack leaking
Posted by MGB 1976
MGB 1976 Avatar
Mark Turechek
Central MA, USA   usa
1976 MG MGB "The Never Ending Project"
Is there a replacement available for the lower gasket on the steering rack for a '76 rubber-bumper MGB? Moss has the top gasket, but I don't think they are interchangeable. I have a gear oil leak from that area. I don't have plans to switch over to grease. Can I buy a new gasket, or make one? Do I need one - can I just use some Permatex to make a gasket and seal it up?
Duane Paulsen
San Diego, USA   usa
1966 Chevrolet Chevy II "Mine"
1976 MG MGB "Jodys MGB"
the lower is a paper gasket the upper is a lip seal, when I rebuilt mine I just cleaned up the gasket with some carb cleaner and used some sealant on it and reused it.
current changes-
Delco 63 amp alternator, Energy/Prothane suspension bushings, front to rear, JVC deck with IPOD controls, new Moss radiator, ADCO front 7/8" sway bar, OD black label trans, chrome bumper conversion, tan leather interior, AA wire block.
future mods-VTO 8 spoke 15x6 wheels (on order)
Aquired parts-
snug top
ozieagle Avatar
Herb Adler
Geelong Victoria, Australia   aus
1958 Wolseley 1500 "Wooly"
1966 MG MGB "Bl**dy B"
I don't know if it is OEM or not, but my steering shaft lower bearing protrudes from the casing about 0.5 mm. Paper gaskets are useless as it won't take up the "slop". What I wound up doing is getting some cork / rubber compound gasket material, about 1.5mm thick and making my own gasket from it.
Herb
trewjohn2001 Avatar
John Trew
Mallorca, Spain   esp
I thought my rack was leaking from there but it turned out to be the pinion shaft seal, it runs down and looks like it comes from that area.
sws615 Avatar
Stephen Struck
Grand Haven, MI, USA   usa
1967 MG MGB GT
2007 Acura TL Type-S
X2 on both Herb and John's comments. If you overfill the rack, it tends to come out of that upper seal until it reaches the appropriate level. winking smiley
