MG-2013 is only 26 days away! · Corvallis, OR · July 17–21, 2013 · Visit MG-2013.com or the MG-2013 Forum for more info
1966 mgb fuel pump run on
Posted by dougwec
doug wechsler
new jersey, USA   usa
My '66 MGB fuel pump delivers gas but continues to click as if it is running on. Anyone have any ideas on the fix - air leak, diaphram?
Thanks
Lee Avatar
Lee
Lee Miller
Mburg, PA, USA   usa
1966 MG MGB
1967 MG MGB
Do you know if it is an SU pump or after market? Aftermarket pumps will tick all the time.
Lee Miller
Experience - hobbyist, rotisserie restoration 1967 MGB, welding, bodywork, painting, wiring, interior, suspension, clutch, engine, SU HS4 carburetors, windshield, and installing convertible top.
Website www.myclassicmg.com
1971 MGB
1967 MGB
1966 MGB restoration project
doug wechsler
new jersey, USA   usa
Original equipment pump
Clay Johnston
Mt. Olive, MS, USA   usa
Either the pump is failing or you have fuel leaking somewhere.
If there's no puddle of fuel under the car...
Pull the vent hoses on the carbs, these should be dry. If either is spitting fuel or wet you need to service the carb floats/float needles.
I would flow test the fuel supply at the carbs. Pull the delivery line at the carbs and redirect into a gallon jug. With pump on you should get about a quart of fuel in 30sec.
Another check, remove the dash pots, turn the pump on. You should not see fuel flowing into the throat. If so, you need to service the float/float needle.
ddubois Avatar
Dave DuBois
Bremerton, WA, USA   usa
Doug - You could have an air leak on the inlet side of the pump (no fuel will leak out) or on the pump itself. To check for an air leak, remove the fuel line at the carbs and direct it into a container, then turn the ignition on and see if the stream of fuel is full of bubbles - if it is, start checking for a loose connection at the tank of the pump, or a crack in the line between the two. Also check that the gasket under the large dome cover (held in place by a single hex head screw on the right side of the pump). Finally, if there is no air leak, you will need to check the inlet and outlet valves in the pump for any debris under the reeds or a cracked reed.
Dave DuBois
1953 MGTD
1966 MGB
SU Fuel Pumps & More SU fuel pump restoration and conversion to solid state. Information and technical articles on SU fuel pumps.
