shorts...opens...that sort of thing
Posted by twigworker
twigworker Avatar
Jack Austin
Blowing Rock, NC, USA   usa
Something that catches my eye from time to time is the incorrect use of the electrical term "short".
I am definitely not an electrical engineer, in fact I would call myself a complete idiot when it comes to much more than wiring up a shop or tracing a car problem, but I do understand a few of the terms.
Understanding and using those terms correctly can greatly aid someone as they try to find the cause of a problem in their car and in helping someone else offer suggestions.
Speaking simply a "short" describes a situation in which an electric supply is offered a diversion to ground before it reaches the intended consumer. Say your right head light doesn't work and you see smoke venting from under the hood. You raise the hood and find that the blue and white wire has been pinched and the metal conductor has been mashed against the fender. You will also note that the blue and white wire is mostly no longer there because the insulation has melted and the conductor has been turned into fried copper.
That is a "short".
On the other hand an "open" is where your headlight doesn't work and you raise the hood only to find that the blue and white wire has become disconnected at one of the gang plugs in the forward wiring harness. The circuit is then considered "open" because the electrons do not have a full circle (circuit) in which to travel from the battery through the switch, through the lamp filament and on to ground, which is of course the other end of the battery ground strap.
I suppose that the easiest way to visualize the differences is to remember that a "short" is usually a situation in which you see smoke, smell something burning or feel excessive heat.
In a way you can also consider a short to sometimes precede an open, simply because if left alone the short will burn up the wiring at some point to the extent that the wire falls away and is no longer in continuity.
Remember that an "open" in itself will not produce smoke, heat or flame. It is simply an interruption in the circuit that can take the form of a disconnected wire or an incomplete connection that looks good but is not electrically capable of passing the electrons.
Jack
---------------------------------------------------- Services to Interesting British Automobiles-- www.jackscars.net ----------------------------------------------------------------
Jacks Cars - Services To Interesting British Automobiles Over 40 years of caring and capable services to British cars and their owners. For help or advice please call 828-295-0224, email to jackscars@charter.net or go to www.jackscars.net.
sws615 Avatar
Stephen Struck
Grand Haven, MI, USA   usa
1967 MG MGB GT
2007 Acura TL Type-S
You con't know how relieved I am Jack. I thought your were going to say my shorts were open. winking smiley
Steve
Jay Bee Avatar
John Baldwin
MANDURAH, Western Australia, Australia   aus
1992 Nissan Patrol SWB Diesel "The Four Wheel Drive"
2005 Hyundai Sonata
Oh Jack. As soon as I saw your heading my mind travelled back to a summers day in 1960. In Aussie land those very abreviated legged pants are called "shorts". I was down from the country visiting the metropolis in my Austin Healey 100. It was in the days before lung cancer police and I was smoking my favourite "makings" or self constructed cigarette. The top was down and I pulled up at a red light along side a bus with three or four teenage girls looking out the window at me. I fancied my self a James Dean look alike in those days and acted accordingly taking a long drag on my cigarette, as I took the thing from my mouth the paper stuck to my lip and my fingers travelled up the cylinder dislodging the red hot tip. Yes it fell into the open leg of my shorts invoking a very unJames Dean response. I can still hear those peals of girlish laughter as I tried desperately to stop the smell of burning body parts as the bus drove away on the green light and my face turned as red as could be. I gave up cigarettes.
Wray Avatar
Wray Lemke
., South Carolina, USA   usa
In reply to # 2100416 by twigworker
Jack
At which point it is now called a "shopen".
alex77 Avatar
alex alcoser
deep south texas, USA   usa
1969 Triumph TR6
1977 MG MGB "Harley Quinn"
1979 Triumph TR7
In reply to # 2100416 by twigworker In a way you can also consider a short to sometimes precede an open, simply because if left alone the short will burn up the wiring at some point to the extent that the wire falls away and is no longer in continuity.
..or a fuse. A good fuse is a short. Reminds me of a story (not sure if its real or not) where a "tech" was complaining that all the fuses were bad because the were "shorted out".
tbarker7815 Avatar
Tom .
Knoxville, TN, USA   usa
A short doesn't have to be a dead short to ground, it can also be an unintended current path, like say the horn wire shorting to the headlight wiring and the lights come on when you push the horn button.
GERONIMO Avatar
Jim Barker
Northeast, IL, USA   usa
1970 MG MGB GT "The Bearcar"
In such a case that the horn activated as well AND the headlights powered on, that would be called a 'cross'. Yet another one of the electrical god's attempt at humor.
Shorts, opens, crosses, how would the world exist without such demons.
Jim B.
twigworker Avatar
Jack Austin
OMG Alex, and that guy makes the big bucks.sad smiley
A good example of a short is a 49 Mercury two door, that has been shaved, sectioned, using lowering blocks, heated coils, reversed wheels with beauty rings, and Frenched lights and radio antenna.
Oh, yea, shorts always have windshield visors and fuzzy dice too.
A three speed gear box with Zephyr gears and all of the seams filled with lead instead of Bondo make it a "Lead Sled Short".thumbs up smiley
Jack
Jim Stabe Avatar
San Diego, USA   usa
A fuse is a device that turns a short into an open at a location that is easy to find - hopefully before it does the damage Jack described.
'66 MGB widened 11" with LT1 Chevy and 6 speed, C4 Corvette suspension
twigworker Avatar
Jack Austin
Like the fuse that kept blowing in the 75 that is sitting in the shop.
Come to find out the idiot that converted the car to a Weber, just whacked the induction heater line and stuffed it down behind the back of the alternator.
On certain occasions, like kissing an expansion joint, the end of the wire, covered in oil and grease I might add, would contact the block for a moment, thus creating a short and converting that into an open.
The real open will occur when the customer has to open his wallet and pay me for fixing yet another six dollar hair cut.
Jack
kstevusa Avatar
kelly stevenson
Lwr. Middle Tennessee, USA   usa
1978 MG MGB "N/A"
Are any of these linked to the "fused link" wire that burns into because of a Poor Ground? This not not isolated to autos alone, since I've seen breakers and receptacles (Plugs)in houses burned also. Note above "Fused Link" is not a wire of smaller gauge as normally used in std. harnesses.
BigIg Avatar
Ian B
E. Yorks, United Kingdom   gbr
I am an electrical Engineer so I can usually tell what people mean when they mis-use electrical terms.
I have more trouble trying to translate the Americanisms. What the hell is a reversed wheel & a Frenched Light?
Ig
kuz1 Avatar
Keith Kuzma
Prattville,Alabama, USA   usa
"Standard rims have a shallow side and a deeper side. The deeper side is the side that goes over the drums or calipers. When the rim is reversed the deep side faces out."
ussually just meeans big offset out
BigIg Avatar
Ian B
Thank you Keith.
- & a Frenched Light?
A French Lite could be a cigarette, I suppose.
warekl Avatar
Keith Ware
White Bear Lake Mn, USA   usa
A light that has what would be the trim ring, moulded into the fender for a sleek streamlined look.
79 RB Lowered, De-smogged, HS4s by Dave Braun & "Schlemmerized" dizzy. Pretty much stock other than that.
frenched light.jpg (9.4 KB) –
djdavies Avatar
David D
Ca, USA   usa
Next up: impedance and impotence.
