MG-2013 is only 59 days away! · Corvallis, OR · July 17–21, 2013 · Visit MG-2013.com or the MG-2013 Forum for more info
Charging problem - Help Please. sad smiley
Posted by oily-hands
oily-hands Avatar
Owen Frankland
Stockton on Tees, Cleveland, United Kingdom   gbr
1937 MG TA "Numbum"
1971 MG MGB GT "The Bruise"
2002 MG ZR
The 71 GT with stock Lucas alternator has a charging problem. The ignition light doesn't come on when switching on, but comes on when started and doesn't go out until about 3000rpm.
Checks so far.
Got 12v at the alternator on the heavy brown wire.
With ignition on 12v at the alternator on the brown/yellow.
Between the brown at the alternator and ground, using 20v scale on digital meter, I get increasing voltage until it goes off scale as the engine is revved.
The ammeter shows discharge when electrics operated but no charge at any revs.
A new regualtor was fitted a few months ago, but that doesn't mean it can't have failed.
Alternators are a bit modern for me so I'm a bit stumped.
Thanks for any help.
Ignition testing made easy.
My You Tube Channel
GILMGA Avatar
Gil Dupre
Chattanooga, TN, USA   usa
1962 MG MGA
1974 MG MGB GT
Go to the MGE library and read UNDERSTANDING ALTERNATORS
Gil
tbarker7815 Avatar
Tom .
Knoxville, TN, USA   usa
I'm thinking regulator is shot.
Wray Avatar
Wray Lemke
., South Carolina, USA   usa
Tom x2. Time for a new/rebuilt alt.
tomkatb Avatar
Larry Baygents
Dayton, Ohio, USA   usa
1963 MG MGB
I vote with Wray
However, if it were me I would.
Pull and clean all battery connections.
Clean alternator connections.
Put a charger on the battery overnight.
Test the battery the next day. Voltage should be 12.7 or higher with the car not running. Running should be a minimum of 13.5. A reading of 12 indicates a bad battery. I have minimal faith in ammeters.
If the light is till on get a new alternator. I would assume you can get one easily.
L.W.(Larry)Baygents
63B
77 Spit
JohnTF Avatar
John F
Northeastern Ohio, USA   usa
1970 MG MGB
1970 MG MGB
Owen, see you are in the other Cleveland.
I would read up a bit, but the local parts stores here will bench test alternators for free, that is an option.
If you have a good relationship with your local mechanic, he may test it for you in place.
My friend John in Cleethorpes says Brit mechanics are friendly and have seen B's before. ;-)
What's the condition of the battery? Does it take a good slow charge from your bench charger?
Am afraid long gone are the days when an alternator was $25, so you could throw parts at a problem -- as my garage says, "there are no more $50 guesses" left.
I put a "police" alternator in my Ford -- it was about $5 more and brightened up things, I have heard of MG police cars. ;-)
Regards, John
gunna Avatar
Thomas Gunnery
Derry NH, USA   usa
1976 MG MGB
You can get an alternator at autozone with a life time warranty. I have replaced two so far no charge after the first one.
RearWing Avatar
Al Mann
Georgetown, KY, USA   usa
In reply to # 2099864 by gunna You can get an alternator at autozone with a life time warranty. I have replaced two so far no charge after the first one.
What make of alternator, Thomas?
Al
Al Mann
Georgetucky, USA.
'71 MGB
'73 Jensen Healey Mk1
'65 Triumph Spitfire IV Mk2
'12 Mini Cooper
stuart sinclair Avatar
honiton, United Kingdom   gbr
1979 MG MGB GT
1998 MG F "RITA"
I had loads of problems with mine last summer after drowning it on a few occasions with rad water the the AA had a go at drowning it so i got one from the BEEHive if you order it in the morning it will arrive the following day,.
Terry Ingoldsby
Calgary, Alberta, Canada   can
If the ignition lamp does not come on when the ignition is switched on, and the engine is not running then a possible cause is bad brushes. Another possible cause would be a bad field coil winding but I have yet to see that failure.
First of all, with the engine off, turn the ignition key on. Remove the plug from the alternator and momentarily ground the brown w/yellow wire. The ignition lamp should glow. If it does, but does not glow when plugged into the alternator, then something is wrong with the field coil circuit. Again, the first thing I would check would be the brushes and commutator - I've seen commutators wear right through!
Quote: Between the brown at the alternator and ground, using 20v scale on digital meter, I get increasing voltage until it goes off scale as the engine is revved.
These two readings are contradictory. I suspect that the AC output or proximity to magnetic fields is confusing your voltmeter. If you really had 20v DC on the alternator output (which is connected to the battery), then the ammeter would show very significant charging of the battery. What happens if you read the voltage at the battery (far from magnetic fields) when you rev the engine? My guess is that you will see nothing but battery voltage (12.6v).
Another thing to check is the status of the plug going into the alternator. I've seen cables that look physically attached, but when you inspect the connection internally, you find that the crimp has loosened with time. This can cause really weird behaviour due to partial connections. You can (carefully) remove the spade connectors from the plastic plug by depressing a little tang on the spade.
It is unusual (but not unheard of) for voltage regulators to fail. The much more common failure is with the rectifier pack. Of course, one failure can induce the other!
Some time ago I wrote up a fairly complete explanation of what the alternator lamp does. You can find it at
http://www.mgexperience.net/phorum/read.php?1,1759313,1759313#msg-1759313
Terry Ingoldsby
terry.ingoldsby@DCExperts.com
gunna Avatar
Thomas Gunnery
Derry NH, USA   usa
1976 MG MGB
I will have to check what make it is when I get home, It's my wife's car and its hard to pry it out of her hands. She drives the thing daily to work and wherever and you should see the look I get when I tell her I am taking it to work. angry smiley
oily-hands Avatar
Owen Frankland
1937 MG TA "Numbum"
2002 MG ZR
Larry, battery & connections are fine.
John F. I can get it tested off the car but haven't got a contact for on car testing yet.
Thoams, what's Autozone when it's at home. grinning smiley
Thanks for the Beehive tip, Stuart
Terry, thanks for that. I was puzzled by the contradictory readings. I'll dig into it a bit deeper when it stops raining.
If it needs a new alternator, so be it, but being a Yorkshireman, if I can fix it for £20 instaed of spending £100, I'll be happy.
My You Tube Channel
Terry Ingoldsby
Quote: If it needs a new alternator, so be it, but being a Yorkshireman, if I can fix it for £20 instaed of spending £100, I'll be happy.
It is almost always cheaper to rebuild a Lucas alternator than to replace it. I've never seen a field or stator coil die on a 16ACR alternator. So, that leaves brushes, bearings, rectifier pack and regulator.
BTW - there were several regulators used (2 wire, 3 wire, 4 wire). They are almost all interchangeable if you know what to connect to what (and I can help you there). You are much closer to the source of parts than most of us - it should be really easy for you.
Terry Ingoldsby
