Tires mounted on original wire wheels
Posted by pete5711
pete5711 Avatar
Pete H
San Antonio, TX, USA   usa
1964 MG MGB "Matilda"
1967 MG MGB
I'm having trouble finding a tire shop that will mount tires for me. All the chains refuse saying something about safety concerns. These chains have essentially killed all the independent shops so now what?
rrmgb Avatar
robert schau
Reston, VA., USA   usa
Have you called many repair shops inquiring?
San Antonio is a pretty big place. Surely someone must be able to mount and balance some tubed tires!
Forget the big stores - go small, independant.
Maybe a mobile type business?
Maybe a Euro shop?
RS
Sir Winston Churchill
G.S.George PHD
TxBrit Avatar
Rodger M
Fort Worth, Texas, USA   usa
1969 MG MGB "Old Yeller"
Had the same problem in Fort Worth, refused at all the main shops but eventually found a small shop who not only fitted the tire and balanced but siliconed all the spokes not protected by the inner band. They even had the correct cones for the balance machine. Perseverance is all I can suggest unfortunately.
dbandel Avatar
David Bandel
Glenwood, Maryland, USA   usa
I just mounted and balanced all five of mine myself using an old set of tire spoons I poached from my father and an older Montgomery Ward bubble level. It works fine as that was the way it was done before tire machines and dynamic balancing. I actually prefer to do wire wheels myself to make sure some knucklehead doesn't damage them using a machine, as the newer tire changers could damage the wheel if the correct adapters are not used. You'd probably want to inspect the inner rim, spokes, the spoke band and tube at the same time anyway. I replaced my old inner tubes and the tube bands with 10 mil poly pipe tape which works really well, too.
-David
Larry Rice
San Antonio TX, USA   usa
Pete,
Bill at Olmos Park Chevron & Auto Center
3903 Mccullough Ave mounted and balanced my wires. He did a fine job mounting although his balancing wasn't too good. I wound up using my bubble balancer afterward with more success. He charged $100 to do the job which seemed kind of expensive but like you I wasn't having any luck anywhere else.
Larry
jaydloon Avatar
Lynn Barney
Des Moines, Iowa, USA   usa
1964 MG MGB
Just a thought, how about a motorcycle shop?
Lynn
64 MGB BRG
Bankerdanny Avatar
Daniel Palmer
Chicagoland, USA   usa
1972 MG MGB GT "Dudley"
1977 Honda MC Gold Wing
I don't know about the balancing part, but hand mounting is not actually as difficult a job as you would think. But you need a set of good long mounting spoons for proper leverage.
Endeavor to Persevere
rdh900 Avatar
robert hughes
east hampton, USA   usa
1972 MG MGB "Maggie B"
Just did one with my old Triumph motorcycle spoons. Piece of cake. That really brought me back!
