everything was going great, and now no start sad smiley
Posted by DiBiaso
pooch2 Avatar
aussie 1968 MK 1
By the Beach, south coast NSW, Australia   aus
Forget the alternator for now.
It only charges battery.
If the battery was low enough to only click, it would never start after the second or third go or anytime.
I know you said the interior light does not dim when you hit key, but did you check the headlights as I suggested?
An interior light would pull about 1/4 amp and would probably dim, but do a further check anyway, it only takes 20 seconds.
Lights on pull about 10 amps, so if there is a bad connection (or a bad cable, as has been suggested, a dude here a while back had same problem as you for a long time ans I think it ended up being a broken/repaired or internally corroded cable half way from battery to starter under car.
This simple check should confirm or rule out battery and cables.
Upon reflection of your negative Pm post, you should read every post and do the simple checks suggested instead of keeping on guessing on one tangent, like you are now with the alternator.
The alternator may well be faulty and weak, but it will not stop a car from starting with a good battery.
You have advice from ONE real person mechanic, (who admittedly has seen your car in person), but you are getting advice by MANY mechanics here.
I usually advise simple checks first so as to rule them out, and get to the harder checks as you progress.
glbishop Avatar
Gary Bishop
Nashua, NH, USA   usa
I thought I had a bad battery and/or starter BUT it ended up being a finicky starter relay.
Here is a quick way to rule out the starter and starter solenoid if it is indeed the relay.
Next time it only clicks or 'nothin' pop the hood and locate the starter relay.
A John Twist video shows exactly how to start your car from under the hood.
Unplug the White/brown stripe wire from the relay and touch it to the bottom fuse clip at the fuse box.
The wire is just long enough to reach and you only need to touch it briefly.
You are by-passing the starter relay and directly energizing the starter solenoid by doing this.
I crank my engine over all the time using this method. Some day I may install a starter button under the hood.
NOTE If you need to start the car and KEEP it running then don't forget to turn the key to the run position first.
pooch2 Avatar
aussie 1968 MK 1
In reply to # 2090052 by glbishop I thought I had a bad battery and/or starter BUT it ended up being a finicky starter relay.
....and make sure car is in NEUTRAL or get run over, very embarrassing..grinning smiley
Kelly Engstrom Avatar
Stanwood WA, USA   usa
Adam, I had the same problem last year. It turned out to be the brown wire from the solenoid junction to the bottom terminal on the fuse box. It had a partial open that tested good for continuity but some times would not carry enough current. I tried a different relay and starter before I figured it out.drinking smiley
JoeReed Avatar
Joe Reed
Cordova, Tennessee, USA   usa
1978 MG MGB "Kermit"
1997 Jaguar XJ6 (X300)
1. It's not the battery. A battery isn't good one second and too weak the next.
2. When you just get the "click"....is it a faint click coming from the starter relay, or a louder click from the starter solenoid? Relay is easy to check and cheap and easy to replace....solenoid/starter not so easy or cheap.
From your previous descriptions I'd bet on a starter solenoid going bad....
tomkatb Avatar
Larry Baygents
Dayton, Ohio, USA   usa
1963 MG MGB
Several years ago my car had a corroded wire attached to the battery clamp. Hard to diagnose.
This inconsistent thing is likely a connection issue. You just have to find it.
Next time you are at a chain automotive store get one of the terminal cleaners. I have worn one out in forty years. All my cars are old.
Hang in there. We have all been through one of these.
Five years from now you will be giving the advice.
L.W.(Larry)Baygents
63B
77 Spit
DiBiaso Avatar
Ad'm DiBiaso
Haverhill, MA, USA   usa
1978 MG MGB
In reply to # 2090086 by JoeReed 1. It's not the battery. A battery isn't good one second and too weak the next.
it is a loud "click." it seems as if when i twist the key twice in quick succession, it starts easily.
i will try to do everything suggested (starting with checking all connections) if i get a chance this week.
i was at least able to get the car running so that i could go out for a drive after all this afternoon. runs fantastically once it's going. was nice to get out there and remind myself that this all worth it grinning smiley
pooch2 Avatar
aussie 1968 MK 1
Yeh, maybe just make sure you stop it on a hill so you can roll start it if you need to drive it while the sun shines until you find the bug.
I think we all roll started/ pushed half dead cars when young.
tomgrigsby Avatar
Tom Grigsby
Ivor, VA, USA   usa
1971 MG MGB GT "The Blight"
1979 MG MGB "The NewB"
deleted - others covered my recommendations already
Edited 1 time(s). Last edit at 06/10/2012 08:05PM by tomgrigsby.
rdgreen Avatar
Robert Green
Adelaide, Australia   aus
Let us know what the problem was when you find it. Good luck.
DiBiaso Avatar
Ad'm DiBiaso
1978 MG MGB
In reply to # 2090670 by rdgreen Let us know what the problem was when you find it. Good luck.
i certainly will. i will be trying out all of the suggestions this coming sunday.
Lee Avatar
Lee
Lee Miller
Mburg, PA, USA   usa
1966 MG MGB
1967 MG MGB
This might be a true statement from a mechanic when I had issues with the Chrysler van. If you turn the key and hear one click it is the starter, if you hear click, click, click, click, it is a weak battery. It was one click, he replaced the starter in the van and issue was fixed. So if you heard click,click,click the solenoid was tring to engage but did not have enough battery power. So begin looking at the starter relay, solenoid, and starter.
Lee Miller
Experience - hobbyist, rotisserie restoration 1967 MGB, welding, bodywork, painting, wiring, interior, suspension, clutch, engine, SU HS4 carburetors, windshield, and installing convertible top.
Website www.myclassicmg.com
1971 MGB
1967 MGB
1966 MGB restoration project
Edited 1 time(s). Last edit at 06/11/2012 07:34AM by Lee.
kdsmgb Avatar
ken stewart
Monterey County, california, USA   usa
Learned something new to me a couple years ago. My two batteries in my diesel Excursion showed a full charge and yet frequently wouldn't start the truck. Autozone hooked up a load testor and found both batteries equally down on cold cranking amps (CCAs)....about 50% down. Two new batteries and problem fixed. Same thing on one of my motorcycles a couple weeks later. These vehicles would start immediately overnight but then not again once I parked. None of the conventional shade tree checks/fixes worked. I now have a harbor freight digital cca testor and always start there when something doesn't start!
spikemichael Avatar
Michael Caputo
Athol, MA, USA   usa
1973 MG MGB "Freebie"
1976 MG MGB "B-4"
1979 MG MGB "MegaBeanie"
1989 Suzuki Intruder 800   → more
So where are you Adam?
Michael J. Caputo
MG CALENDARS! MGB or MGA order TODAY!   – Athol, MA USA $20 delivered anywhere! Visit www.mgbcalendar.com or CALL 617-674-4367
