Fuel pump clicking but no fuel
sflaherty Sam F
Northwest, USA   USA
1976 MG MGB
Hi All,
Rebuilt my 1976 MGB carb and completely replaced the clutch cylinder and master slave. My 15 year old daughter helped me. It was 10 pm when we finished the clutch. We were so excited to finally go for a spin. Started, ready....stopped. Pump is clicking but no fuel. What would be best quick trouble shooting? Thanks!
curtis7420 Avatar
curtis7420 Curtis Wright
University City, MO, USA   USA
is there a fuel filter attached? if so, is it new or old? sounds like it may be clogged...
pull the line to make sure that fuel is being pumped out...
good luck
sflaherty Sam F
Northwest, USA   USA
1976 MG MGB
Filter is new and can see fuel is getting there. I am thinking plugged line?
sflaherty Sam F
Northwest, USA   USA
1976 MG MGB
Sorry....Fuel NOT getting to filter.
mgcgt2912 Richard Bailey
Cully, East Devon England, UK   GBR
If the line between pump and carbs is blocked ..then the pump will stop ticking.
If I remember rightly it happened to me once a long time ago after I had fitted a new pump.It was ticking away like a good'un but only fresh air getting to carbs.
Some sort air leak ( or lock) between tank and pump. Never did find out exactly what it was. Just refitted the pipe connections and it cured it
R
sflaherty Sam F
Northwest, USA   USA
1976 MG MGB
Good tip. Thanks
pleblanc1206 Avatar
pleblanc1206 Gold Member Pierre Leblanc
Saline, MI, USA   USA
1974 MG MGB GT "The MG"
2013 Scion FR-S
In reply to # 2083200 by mgcgt2912 If the line between pump and carbs is blocked ..then the pump will stop ticking.
R
This happened to me last year after installing a new Facet pump and filter. There was a leak between the tank and pump, and air was getting sucked in causing a constant ticking and very little fuel getting to the carbs. The fitting on the side of the tank broke loose and then fuel started leaking from there. I rebonded the fitting to the side of the tank with JB Weld and its been fine for the past year.
1974 MGB-GT: black-label overdrive, essentially stock detoxed engine, Schlemmerized distributor.
curtis7420 Avatar
if it's a "lock" then would it help to play around with the gas cap? try taking it off and on while attempting to start it...
honestly, i have no idea, but that's something i would try...certainly couldn't hurt anything
ThinkingD Avatar
ThinkingD Tim Dowell
Ottawa, Ontario, Canada   CAN
The pump is most likely sucking air not gas. Check the hoses especially around the pump itself for leaks or loose connections.
ddubois Avatar
Bremerton, WA, USA   USA
Sam - You don't say what kind of pump is in your car. If it is an aftermarket pump like a Facet, it will chatter away regardless of clogs on either side of the pump. If you have a SU pump, a clog on either side of the pump will cause it to stall and if it is on the inlet side of the pump, the pump will get hot.
I am going to approach this as though you have a SU pump in the car. The very first thing that I would consider is an air leak on the inlet side of the pump.
How long was the pump sitting while you were fussing with the carburetors? If it was a month or so, the fuel could have evaporated out to the pump, allowing the valves to dry out, causing them to loose a good seal. First try tightening the screws around the flange of the coil housing. If this doesn't get the pump working, remove the line going from the vapor separator. Rig a line to the outlet fitting on the separator. Turn the ignition on and let the pump rattle away while you blow into the line rigged up to the separator. If dry valves are the culprit, the pump should start pumping fuel in a few seconds. If this works, your pump is probably a good candidate for rebuild. If this doesn't work, then restore the normal plumbing to the separator and attach the line to the inlet side of the pump and dip it into a can of fuel. Turn the ignition on and see if the pump start pumping fuel - it it does, there is a problem in the line from the tank to the pump. If it doesn't start pumping fuel, then remove the large domed cap on the side of the pump (held in place with a single hes head screw) and check the condition of the cork gasket under it. If it is cracked, torn or other wise not in good shape, replace it. If this doesn't work, is definitely time for a rebuild of the pump (or a new pump).
Dave DuBois
1953 MGTD
1966 MGB
pcadogan Avatar
pcadogan pat c
ok, USA   USA
1973 MG MGB "Eliza Jane"
Blocked screen in the tank?
sflaherty Sam F
Northwest, USA   USA
1976 MG MGB
In reply to # 2083243 by ddubois Sam - You don't say what kind of pump is in your car. If it is an aftermarket pump like a Facet, it will chatter away regardless of clogs on either side of the pump. If you have a SU pump, a clog on either side of the pump will cause it to stall and if it is on the inlet side of the pump, the pump will get hot.
Dave,
Thanks. I disconnected the intake to pump from tank and blew some air. Immediately gas came rushing out everywhere. I hurriedly replaced the line figuring there may have been a clog in the line. No dice. Still clicking away without fuel. The pump doesn't look original SU. I will check.
sflaherty Sam F
Northwest, USA   USA
1976 MG MGB
In reply to # 2083277 by sflaherty
Dave,
It is SU. I will try as described.
1975 MG MGB
